[GRASS-git] [OSGeo/grass] 552e00: gui(nviz): Type hinting to the nviz library wrappe...
    Edouard Choinière
    noreply at github.com
    Mon Jan 27 16:50:14 PST 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 552e00b8978ede232f134a4303124bc99a06d4da
      https://github.com/OSGeo/grass/commit/552e00b8978ede232f134a4303124bc99a06d4da
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Date:   2025-01-27 (Mon, 27 Jan 2025)
  Changed paths:
    M gui/wxpython/core/gcmd.py
    M gui/wxpython/core/utils.py
    M gui/wxpython/gui_core/wrap.py
    M gui/wxpython/mapdisp/frame.py
    M gui/wxpython/mapswipe/mapwindow.py
    M gui/wxpython/nviz/mapwindow.py
    M gui/wxpython/nviz/wxnviz.py
  Log Message:
  gui(nviz): Type hinting to the nviz library wrapper and various related improvements (#4899)
* gui.wxpython.nviz: numpy import can safely be below
* gui.wxpython.nviz: Move ctypes and grass.lib imports below normal imports
There is no reason (dependency of imports) apparent here that would prevent it from working.
Works locally in a Ubuntu 22.04 WSL on Windows
* gui.wxpython.nviz: Sort remaining imports
grass.script was already below gui imports in 2023
* gui.wxpython.nviz: Set render flags dicts as a TypedDict
This allows static analysis of self.render dict, that contains 4 keys and all boolean values
* gui.wxpython.nviz.mapwindow: Light typing annotations
* gui.wxpython.nviz.mapwindow: GetContentScaleFactor() typing annotations
* gui.wxpython.nviz: Make GLWindow.ZoomToMap()'s layer argument optional
* gui.wxpython.core.utils: PIL.Image and wx.Image type annotations
* gui.wxpython.gui_core.wrap: wx.Image and wx.Bitmap type annotations
* gui.wxpython.gui_core.wrap: wx.Rect and other type annotations
* gui.wxpython.core.gcmd: Add typing and overloads for EncodeString and DecodeString
* gui: isort mapswipe.mapwindow imports
* gui.wxpython.mapswipe.mapwindow: Add type hints related to wx.Size
* gui.wxpython.nviz.wxnviz: Add type hints for OGSF/Nviz wrappers
Includes using different aliases for different type of ids, to be able to check for usage mismatches
* gui.wxpython.nviz.wxnviz: Add type hints for QueryMap with TypedDict
gui.wxpython.nviz.wxnviz: Add some type hints for Texture and ImageTexture
* gui.wxpython.nviz.wxnviz: Add typing to functions that return empty vectors, considered tuples
* gui.wxpython.nviz.wxnviz: Address type checking warnings in QueryMap
When results of GetPointOnSurface() is None, ensure that we return None, and the other branch is assured to contain floats
* gui.wxpython.nviz.wxnviz: Remove unused import
* gui.wxpython.nviz.mapwindow: Sort imports with an isort split group
* gui.wxpython.nviz.mapwindow: Add some type hints
* gui.wxpython.mapdisp.frame: Sort imports with an isort split group
* gui.wxpython.nviz.mapwindow: Handle some cases where self._display is None or other variables are missing
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
