[GRASS-git] [OSGeo/grass] 33efef: CI(deps): Update github/codeql-action action to v3...
Edouard Choinière
noreply at github.com
Mon Jan 27 19:36:12 PST 2025
Branch: refs/heads/renovate/ruff
Home: https://github.com/OSGeo/grass
Commit: 33efefac5a39e616e0de6fcb26fc888debf0fb8d
https://github.com/OSGeo/grass/commit/33efefac5a39e616e0de6fcb26fc888debf0fb8d
Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Date: 2025-01-23 (Thu, 23 Jan 2025)
Changed paths:
M .github/workflows/codeql-analysis.yml
M .github/workflows/python-code-quality.yml
M renovate.json5
Log Message:
CI(deps): Update github/codeql-action action to v3.28.4 (#4981)
Commit: e95709fb675999132f2cb99edc4c59a42d885cd0
https://github.com/OSGeo/grass/commit/e95709fb675999132f2cb99edc4c59a42d885cd0
Changed paths:
M .github/workflows/pytest.yml
Log Message:
CI(deps): Update codecov/codecov-action action to v5.3.0 (#4983)
Commit: bb58173b8c47a067ce67b9282c7e00388ef0f699
https://github.com/OSGeo/grass/commit/bb58173b8c47a067ce67b9282c7e00388ef0f699
Author: Anna Petrasova <kratochanna at gmail.com>
Changed paths:
A raster/r.sim/r.sim.sediment/testsuite/data/depth_default.pack
A raster/r.sim/r.sim.sediment/testsuite/data/reference_erdep.pack
A raster/r.sim/r.sim.sediment/testsuite/data/reference_sedflux.pack
A raster/r.sim/r.sim.sediment/testsuite/test_r_sim_sediment.py
Log Message:
r.sim.sediment: add simple test (#4978)
Commit: 1c956f76255e76c5c19ed71cbe29a2fcded62f4a
https://github.com/OSGeo/grass/commit/1c956f76255e76c5c19ed71cbe29a2fcded62f4a
Author: Nishant Bansal <103022832+NishantBansal2003 at users.noreply.github.com>
Date: 2025-01-24 (Fri, 24 Jan 2025)
Changed paths:
M raster/r.describe/Makefile
M raster/r.describe/describe.c
M raster/r.describe/dumplist.c
M raster/r.describe/local_proto.h
M raster/r.describe/main.c
A raster/r.describe/testsuite/test_r_describe.py
Log Message:
r.describe: Add JSON support (#4918)
Commit: ff7cebd51334df6b1c666e05a6f427ca050520c7
https://github.com/OSGeo/grass/commit/ff7cebd51334df6b1c666e05a6f427ca050520c7
Date: 2025-01-25 (Sat, 25 Jan 2025)
Changed paths:
Log Message:
CI(deps): Update github/codeql-action action to v3.28.5 (#4986)
Co-authored-by: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Commit: e5dfe6cac55e8e05af1bbb7915c680e934949597
https://github.com/OSGeo/grass/commit/e5dfe6cac55e8e05af1bbb7915c680e934949597
Changed paths:
M .github/workflows/docker.yml
Log Message:
CI(deps): Update docker/build-push-action action to v6.13.0 (#4987)
Commit: 3ee3252390a1a1dca5d7c13e859c85efe3c9ca42
https://github.com/OSGeo/grass/commit/3ee3252390a1a1dca5d7c13e859c85efe3c9ca42
Changed paths:
M .pre-commit-config.yaml
Log Message:
CI(deps): Update pre-commit hook igorshubovych/markdownlint-cli to v0.44.0 (#4988)
Commit: c0b45cfe22e13bf6ab2bffb9d9e6f6bba54f9798
https://github.com/OSGeo/grass/commit/c0b45cfe22e13bf6ab2bffb9d9e6f6bba54f9798
Changed paths:
Log Message:
CI(deps): Update codecov/codecov-action action to v5.3.1 (#4985)
Commit: 71f1bce71173a18d4efe6708e99e5f63f46e34d1
https://github.com/OSGeo/grass/commit/71f1bce71173a18d4efe6708e99e5f63f46e34d1
Author: Arohan Ajit <arohanajit232 at gmail.com>
Date: 2025-01-27 (Mon, 27 Jan 2025)
Changed paths:
A .DS_Store
M .flake8
M gui/wxpython/vdigit/main.py
M gui/wxpython/vdigit/wxdigit.py
A raster/.DS_Store
Log Message:
wxGUI: Fixed star imports in wxdigit.py (#4973)
Commit: 552e00b8978ede232f134a4303124bc99a06d4da
https://github.com/OSGeo/grass/commit/552e00b8978ede232f134a4303124bc99a06d4da
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Changed paths:
M gui/wxpython/core/gcmd.py
M gui/wxpython/core/utils.py
M gui/wxpython/gui_core/wrap.py
M gui/wxpython/mapdisp/frame.py
M gui/wxpython/mapswipe/mapwindow.py
M gui/wxpython/nviz/mapwindow.py
M gui/wxpython/nviz/wxnviz.py
Log Message:
gui(nviz): Type hinting to the nviz library wrapper and various related improvements (#4899)
* gui.wxpython.nviz: numpy import can safely be below
* gui.wxpython.nviz: Move ctypes and grass.lib imports below normal imports
There is no reason (dependency of imports) apparent here that would prevent it from working.
Works locally in a Ubuntu 22.04 WSL on Windows
* gui.wxpython.nviz: Sort remaining imports
grass.script was already below gui imports in 2023
* gui.wxpython.nviz: Set render flags dicts as a TypedDict
This allows static analysis of self.render dict, that contains 4 keys and all boolean values
* gui.wxpython.nviz.mapwindow: Light typing annotations
* gui.wxpython.nviz.mapwindow: GetContentScaleFactor() typing annotations
* gui.wxpython.nviz: Make GLWindow.ZoomToMap()'s layer argument optional
* gui.wxpython.core.utils: PIL.Image and wx.Image type annotations
* gui.wxpython.gui_core.wrap: wx.Image and wx.Bitmap type annotations
* gui.wxpython.gui_core.wrap: wx.Rect and other type annotations
* gui.wxpython.core.gcmd: Add typing and overloads for EncodeString and DecodeString
* gui: isort mapswipe.mapwindow imports
* gui.wxpython.mapswipe.mapwindow: Add type hints related to wx.Size
* gui.wxpython.nviz.wxnviz: Add type hints for OGSF/Nviz wrappers
Includes using different aliases for different type of ids, to be able to check for usage mismatches
* gui.wxpython.nviz.wxnviz: Add type hints for QueryMap with TypedDict
gui.wxpython.nviz.wxnviz: Add some type hints for Texture and ImageTexture
* gui.wxpython.nviz.wxnviz: Add typing to functions that return empty vectors, considered tuples
* gui.wxpython.nviz.wxnviz: Address type checking warnings in QueryMap
When results of GetPointOnSurface() is None, ensure that we return None, and the other branch is assured to contain floats
* gui.wxpython.nviz.wxnviz: Remove unused import
* gui.wxpython.nviz.mapwindow: Sort imports with an isort split group
* gui.wxpython.nviz.mapwindow: Add some type hints
* gui.wxpython.mapdisp.frame: Sort imports with an isort split group
* gui.wxpython.nviz.mapwindow: Handle some cases where self._display is None or other variables are missing
Commit: 54553dff8b6855307ca43640e3843ef86d871f4d
https://github.com/OSGeo/grass/commit/54553dff8b6855307ca43640e3843ef86d871f4d
Changed paths:
M mswindows/osgeo4w/build_osgeo4w.sh
M mswindows/osgeo4w/package.sh
Log Message:
Windows: Apply OSGeo4W patches for Postgres (#4996)
Commit: 24b2eddc79d9c93660aeeac343bbda1e6a62b802
https://github.com/OSGeo/grass/commit/24b2eddc79d9c93660aeeac343bbda1e6a62b802
Changed paths:
A .DS_Store
M .flake8
A raster/.DS_Store
M renovate.json5
Log Message:
Merge branch 'main' into renovate/ruff
Compare: https://github.com/OSGeo/grass/compare/6b79df915ce1...24b2eddc79d9
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
