[GRASS-git] [OSGeo/grass] 56109d: docs: Fix Doxygen warnings due to invalid docstrin...
Edouard Choinière
noreply at github.com
Thu Jul 24 14:17:14 PDT 2025
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 56109d36f52c71bbd4404417af9f6e0a95b956de
https://github.com/OSGeo/grass/commit/56109d36f52c71bbd4404417af9f6e0a95b956de
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2025-07-24 (Thu, 24 Jul 2025)
Changed paths:
M grasslib.dox
M imagery/i.group/main.c
M include/Make/Doxyfile_arch_html.in
M include/Make/Doxyfile_arch_latex.in
M include/grass/dbmi.h
M include/grass/ogsf.h
M include/grass/vect/dig_defines.h
M include/grass/vect/dig_externs.h
M include/grass/vect/dig_macros.h
M include/grass/vect/dig_structs.h
M lib/datetime/type.c
M lib/db/dbmi_base/table.c
M lib/db/dbmi_client/c_list_idx.c
M lib/db/dbmi_client/copy_tab.c
M lib/display/r_raster.c
M lib/display/raster2.c
M lib/display/setup.c
M lib/display/tran_colr.c
M lib/gis/asprintf.c
M lib/gis/basename.c
M lib/gis/file_name.c
M lib/gis/find_file.c
M lib/gis/lrand48.c
M lib/gis/lz4.h
M lib/gis/nme_in_mps.c
M lib/gis/open_misc.c
M lib/gis/parser.c
M lib/gis/paths.c
M lib/gis/rd_cellhd.c
M lib/gis/tempfile.c
M lib/gis/wind_format.c
M lib/gis/wind_scan.c
M lib/gmath/fft.c
M lib/gmath/la.c
M lib/gmath/rand1.c
M lib/imagery/find.c
M lib/imagery/list_gp.c
M lib/imagery/manage_signatures.c
M lib/imagery/sig.c
M lib/imagery/sigset.c
M lib/nviz/cplanes_obj.c
M lib/ogsf/gp.c
M lib/ogsf/gs.c
M lib/ogsf/gs2.c
M lib/ogsf/gsd_objs.c
M lib/ogsf/gsd_views.c
M lib/ogsf/gsdrape.c
M lib/proj/convert.c
M lib/raster/mask_info.c
M lib/raster3d/headerinfo.c
M lib/raster3d/mask.c
M lib/raster3d/open.c
M lib/raster3d/open2.c
M lib/raster3d/resample.c
M lib/raster3d/windowio.c
M lib/vector/Vlib/area.c
M lib/vector/Vlib/cats.c
M lib/vector/Vlib/close.c
M lib/vector/Vlib/intersect.c
M lib/vector/Vlib/intersect2.c
M lib/vector/Vlib/level_two.c
M lib/vector/Vlib/net_analyze.c
M lib/vector/Vlib/open.c
M lib/vector/Vlib/read_nat.c
M lib/vector/Vlib/simple_features.c
M lib/vector/neta/timetables.c
M lib/vector/vedit/zbulk.c
Log Message:
docs: Fix Doxygen warnings due to invalid docstring syntax or missing tags (#6097)
Similar to the bunch of fixes I did with sphinx in the last months or so, here is a first PR solving Doxygen warnings that can now be seen in CI (since #6092).
It is a first batch with what I have yet, no particular grouping expect at the commit level.
- Make doxygen ignore CMake build folders when looking for source documents, like in https://github.com/OSGeo/grass/pull/5191 and https://github.com/OSGeo/grass/pull/5208
- Fix wrong parameter names in docstrings
- Add non documented parameters to the docstrings
- Feel free to suggest some content when they didn’t exist yet, I went the easiest way that wasn’t creating something misleading. So when I didn’t know, I didn’t describe it at all.
- fix syntax, and escape some characters when complaining
- A small number of files I had to reflow the docstrings to be readable again, as it was joined together probably by a clang-format once. So these have a bigger diff.
There’s still lots of the same categories, it’s only what I had done yet.
* docs(lib): Update parameter descriptions for to match function signature
* docs(lib): Fix formatting of parameter descriptions to solve doxygen warnings
* man: Ignore cmake folders in doxygen config file
* docs(lib): Update parameter descriptions to match function signature
* lib/display/tran_colr: Fill docs for D_color_number_to_RGB according to signature
* lib/display/raster2 Update parameter descriptions to match function signature
* include: Update file paths in header comments to include 'grass' directory
* docs: Escape `@`, `<` or `>` in doxygen docstrings
* docs: Add missing param tags in doxygen docstrings
* docs: Rename param tags to match signature in doxygen docstrings
* docs: Escape `/*` to avoid nested comment warning in grasslib.dox
* docs: Fix misformed `<b>` tag in doxygen docstrings of lib/gmath/fft.c
* docs: Document parameters and returns in doxygen docstrings
* docs(lib): Fix formatting of lz4.h
* docs: Fix typo in file name of lib/imagery/manage_signatures.c header
* Apply suggestions from code review
Co-authored-by: Anna Petrasova <kratochanna at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
