[GRASS-git] [OSGeo/grass-addons] 5bc288: r.lfp: Add a new longest flow path addon (#1443)
Huidae Cho
noreply at github.com
Fri Jul 25 08:52:38 PDT 2025
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: 5bc288b3e84e7cc4f51815613e156b470ba5dc40
https://github.com/OSGeo/grass-addons/commit/5bc288b3e84e7cc4f51815613e156b470ba5dc40
Author: Huidae Cho <grass4u at gmail.com>
Date: 2025-07-25 (Fri, 25 Jul 2025)
Changed paths:
A src/raster/r.lfp/Makefile
A src/raster/r.lfp/direction.c
A src/raster/r.lfp/gettimeofday.c
A src/raster/r.lfp/global.h
A src/raster/r.lfp/lfp_funcs.h
A src/raster/r.lfp/main.c
A src/raster/r.lfp/outlet_list.c
A src/raster/r.lfp/outlets.c
A src/raster/r.lfp/point_list.c
A src/raster/r.lfp/r.lfp.html
A src/raster/r.lfp/r.lfp.md
A src/raster/r.lfp/r_lfp_custom_formats.png
A src/raster/r.lfp/r_lfp_elev_state_500m_example.png
A src/raster/r.lfp/r_lfp_elevation_example.png
A src/raster/r.lfp/r_lfp_formats.png
A src/raster/r.lfp/timeval_diff.c
A src/raster/r.lfp/write.c
Log Message:
* r.lfp: Add a new longest flow path addon
* Correct outlets to dcells
* Add the link to MELFP
* Fix the type of tss option
* Merge lfp_lessmem.c to main.c
* Split long labels into descriptions
* Shorten option names (for Python API?)
* Move floating point out of abs()
* Suppress a clang -Wsometimes-uninitialized; pop_up() is called only if n > 1 anyway
* Remove unused parameters
* Suppress gcc -Wmaybe-uninitialized when used with -O3
* Reorder links in SEE ALSO
* Removed unsed macros
* Add flow direction formats in the manual
* Correct the explanation for the example
* Add more details about the algorithm in the manual
* Mention the parallel computing technology
* Syntax in the manual
* Add an NC statewide example
* Rename input option to direction because there are more than one input map
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
