[GRASS-git] [OSGeo/grass] da4095: CQ: Trim newline between Doxygen docstring and fun...
Edouard Choinière noreply at github.com
Sun Jul 27 02:53:52 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: da409580ef15011f3bac379c76d41101c9e36347
      https://github.com/OSGeo/grass/commit/da409580ef15011f3bac379c76d41101c9e36347
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Date:   2025-07-27 (Sun, 27 Jul 2025)
  Changed paths:
    M db/drivers/odbc/table.c
    M db/drivers/sqlite/create_table.c
    M db/drivers/sqlite/describe.c
    M db/drivers/sqlite/execute.c
    M db/drivers/sqlite/fetch.c
    M db/drivers/sqlite/index.c
    M db/drivers/sqlite/listtab.c
    M db/drivers/sqlite/select.c
    M imagery/i.atcorr/computations.cpp
    M imagery/i.cluster/print3.c
    M imagery/i.ortho.photo/lib/error.c
    M imagery/i.ortho.photo/lib/georef.c
    M imagery/i.ortho.photo/lib/isnull.c
    M imagery/i.ortho.photo/lib/m_add.c
    M imagery/i.ortho.photo/lib/m_copy.c
    M imagery/i.ortho.photo/lib/m_inverse.c
    M imagery/i.ortho.photo/lib/m_mult.c
    M imagery/i.ortho.photo/lib/m_transpose.c
    M imagery/i.ortho.photo/lib/m_zero.c
    M imagery/i.smap/multialloc.c
    M lib/bitmap/bitmap.c
    M lib/bitmap/sparse.c
    M lib/cdhc/royston.c
    M lib/datetime/between.c
    M lib/datetime/change.c
    M lib/datetime/copy.c
    M lib/datetime/diff.c
    M lib/datetime/error.c
    M lib/datetime/format.c
    M lib/datetime/incr1.c
    M lib/datetime/incr2.c
    M lib/datetime/incr3.c
    M lib/datetime/local.c
    M lib/datetime/misc.c
    M lib/datetime/same.c
    M lib/datetime/scan.c
    M lib/datetime/sign.c
    M lib/datetime/type.c
    M lib/datetime/tz1.c
    M lib/datetime/tz2.c
    M lib/datetime/values.c
    M lib/db/stubs/close_cursor.c
    M lib/display/cnversions.c
    M lib/display/draw2.c
    M lib/display/r_raster.c
    M lib/display/raster2.c
    M lib/display/symbol.c
    M lib/display/tran_colr.c
    M lib/dspf/cube_io.c
    M lib/gis/alloc.c
    M lib/gis/area.c
    M lib/gis/area_poly1.c
    M lib/gis/area_sphere.c
    M lib/gis/ascii_chk.c
    M lib/gis/asprintf.c
    M lib/gis/commas.c
    M lib/gis/copy_dir.c
    M lib/gis/done_msg.c
    M lib/gis/geodist.c
    M lib/gis/get_projinfo.c
    M lib/gis/is.c
    M lib/gis/locale.c
    M lib/gis/lrand48.c
    M lib/gis/mach_name.c
    M lib/gis/make_loc.c
    M lib/gis/mapcase.c
    M lib/gis/mkstemp.c
    M lib/gis/myname.c
    M lib/gis/omp_threads.c
    M lib/gis/open.c
    M lib/gis/open_misc.c
    M lib/gis/overwrite.c
    M lib/gis/parser.c
    M lib/gis/plot.c
    M lib/gis/remove.c
    M lib/gis/rhumbline.c
    M lib/gis/short_way.c
    M lib/gis/snprintf.c
    M lib/gis/spawn.c
    M lib/gis/token.c
    M lib/gis/units.c
    M lib/gis/user_config.c
    M lib/gis/view.c
    M lib/gis/wind_2_box.c
    M lib/gis/wind_in.c
    M lib/gis/wind_limits.c
    M lib/gis/wind_overlap.c
    M lib/gis/wr_cellhd.c
    M lib/gis/writ_zeros.c
    M lib/gis/zone.c
    M lib/gmath/blas_level_2.c
    M lib/gmath/dalloc.c
    M lib/gmath/del2g.c
    M lib/gmath/fft.c
    M lib/gmath/findzc.c
    M lib/gmath/gauss.c
    M lib/gmath/la.c
    M lib/gmath/max_pow2.c
    M lib/gmath/mult.c
    M lib/gmath/rand1.c
    M lib/imagery/find.c
    M lib/imagery/group.c
    M lib/imagery/iscatt_core.c
    M lib/imagery/list_subgp.c
    M lib/imagery/points.c
    M lib/imagery/target.c
    M lib/imagery/var.c
    M lib/nviz/nviz.c
    M lib/pngdriver/box.c
    M lib/pngdriver/color.c
    M lib/pngdriver/draw_bitmap.c
    M lib/pngdriver/graph_set.c
    M lib/proj/ellipse.c
    M lib/raster/align_window.c
    M lib/raster/alloc_cell.c
    M lib/raster/auto_mask.c
    M lib/raster/cats.c
    M lib/raster/cell_title.c
    M lib/raster/color_rand.c
    M lib/raster/color_xform.c
    M lib/raster/histogram.c
    M lib/raster/init.c
    M lib/raster/open.c
    M lib/raster/set_window.c
    M lib/raster/window.c
    M lib/raster3d/alloc.c
    M lib/raster3d/cats.c
    M lib/raster3d/changeprecision.c
    M lib/raster3d/changetype.c
    M lib/raster3d/defaults.c
    M lib/raster3d/error.c
    M lib/raster3d/filecompare.c
    M lib/raster3d/getblock.c
    M lib/raster3d/getvalue.c
    M lib/raster3d/header.c
    M lib/raster3d/headerinfo.c
    M lib/raster3d/history.c
    M lib/raster3d/mask.c
    M lib/raster3d/null.c
    M lib/raster3d/open.c
    M lib/raster3d/open2.c
    M lib/raster3d/param.c
    M lib/raster3d/putvalue.c
    M lib/raster3d/range.c
    M lib/raster3d/region.c
    M lib/raster3d/resample.c
    M lib/raster3d/retile.c
    M lib/raster3d/tilealloc.c
    M lib/raster3d/tileio.c
    M lib/raster3d/tilemath.c
    M lib/raster3d/tilenull.c
    M lib/raster3d/tileread.c
    M lib/raster3d/tilewrite.c
    M lib/raster3d/window.c
    M lib/raster3d/windowio.c
    M lib/raster3d/writeascii.c
    M lib/rowio/put.c
    M lib/rowio/setup.c
    M lib/rst/interp_float/func2d.c
    M lib/rst/interp_float/point2d.c
    M lib/rst/interp_float/point2d_parallel.c
    M lib/segment/address.c
    M lib/segment/close.c
    M lib/segment/flush.c
    M lib/segment/format.c
    M lib/segment/get.c
    M lib/segment/get_row.c
    M lib/segment/init.c
    M lib/segment/open.c
    M lib/segment/pagein.c
    M lib/segment/pageout.c
    M lib/segment/put.c
    M lib/segment/put_row.c
    M lib/segment/release.c
    M lib/segment/setup.c
    M lib/vector/Vlib/area.c
    M lib/vector/Vlib/array.c
    M lib/vector/Vlib/break_lines.c
    M lib/vector/Vlib/header.c
    M lib/vector/Vlib/legal_vname.c
    M lib/vector/Vlib/merge_lines.c
    M lib/vector/Vlib/net_analyze.c
    M lib/vector/Vlib/net_build.c
    M lib/vector/Vlib/remove_areas.c
    M lib/vector/diglib/allocation.c
    M lib/vector/diglib/plus_struct.c
    M lib/vector/diglib/poly.c
    M lib/vector/diglib/spindex.c
    M lib/vector/diglib/spindex_rw.c
    M lib/vector/rtree/index.c
    M lib/vector/rtree/node.c
    M ps/ps.map/catval.c
    M ps/ps.map/gprims.c
    M raster/r.buffer/find_dist.c
    M raster/r.fill.stats/cell_funcs.c
    M raster/r.flow/aspect.h
    M raster/r.flow/flow_io.h
    M raster/r.flow/mem.h
    M raster/r.flow/precomp.h
    M raster/r.li/r.li.daemon/daemon.h
    M raster/r.neighbors/bufs.c
    M raster/r.out.pov/main.c
    M raster/r.out.vrml/put_grid.c
    M raster/r.out.vrml/vrml.c
    M raster/r.patch/do_patch.c
    M raster/r.patch/support.c
    M raster/r.report/sums.c
    M raster/r.viewshed/viewshed.cpp
    M raster3d/r3.out.v5d/main.c
    M raster3d/r3.showdspf/thresh_array.c
    M vector/v.clean/prune.c
    M vector/v.in.ascii/points.c
    M vector/v.net/turntable.c
    M vector/v.perturb/zufallrs.c
    M vector/v.perturb/zufallsv.c
    M vector/v.surf.idw/read_sites.c
    M vector/v.to.db/lines.c
    M vector/v.vol.rst/user1.c
    M vector/v.voronoi/vo_extend.c
  Log Message:
  CQ: Trim newline between Doxygen docstring and function signature (#6122)
Even if the current version of Doxygen doesn't complain much, different parsers in an IDE, like VSCode, doesn't recognize the block comment above when there are extra newlines.
Used the following regex to find possible candidates:
\n\s(?:\*)\/\n\n((?:\w* [\*]*)+[\w]*\()
And replaced with:
\n */\n$1
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
