[GRASS-git] [OSGeo/grass] 4f0830: docs: Fix unescaped substitutions and emphasis, va...
    Edouard Choinière
    noreply at github.com
    Tue Jun  3 20:24:33 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 4f08307e85e87a8083fcc1d8f3e9371afa790903
      https://github.com/OSGeo/grass/commit/4f08307e85e87a8083fcc1d8f3e9371afa790903
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Date:   2025-06-03 (Tue, 03 Jun 2025)
  Changed paths:
    M python/grass/docs/src/script_intro.rst
    M python/grass/gunittest/testsuite/test_checkers.py
    M python/grass/imaging/images2avi.py
    M python/grass/pygrass/modules/interface/module.py
    M python/grass/pygrass/utils.py
    M python/grass/pygrass/vector/__init__.py
    M python/grass/pygrass/vector/geometry.py
    M python/grass/script/core.py
    M python/grass/temporal/abstract_map_dataset.py
    M python/grass/temporal/abstract_space_time_dataset.py
    M python/grass/temporal/base.py
    M python/grass/temporal/temporal_algebra.py
    M python/grass/temporal/temporal_operator.py
    M python/grass/temporal/temporal_raster_base_algebra.py
    M python/grass/temporal/temporal_vector_algebra.py
  Log Message:
  docs: Fix unescaped substitutions and emphasis, various typos or simple issues (#5826)
* docs: Fix typo in docstring of python/grass/pygrass/utils.py findmaps()
* docs: Fix formatting issues of unescaped substitutions or emphasis
* docs: Fix formatting issue of bullet list of TemporalOperatorParser.parse()
* docs: Fix simple typos
* docs: Fix code block missing double colon
* docs: Fix space between double colon of a code block + change to pycon language
* docs: Fix list formatting for python/grass/imaging/images2avi.py writeAvi()
* docs: Unindent docstring for AbstractSpaceTimeDataset.register_map
* docs: Fix underline too short in script_intro.rst
* docs: Fix docstring formating for grass.script.core.tempname()
* docs: Hide c_read_next_line() and c_read_line() in python/grass/pygrass/vector/geometry.py
* docs: Use double backticks for inline code in pygrass.vector.geometry
* docs: Format args and kwargs param in gs.write_command
* docs: Fix type field-list in features_to_wkb_list() of pygrass.vector docstring
* docs: Fix python 2 code blocks in pygrass.modules.interface docstrings
* Apply ruff format
* Update geometry.py
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
