[GRASS-git] [OSGeo/grass] e1e37d: raster: fix typos (#5266)
luzpaz noreply at github.com
Fri Mar 7 04:40:09 PST 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: e1e37d87e78212dfcf4c97aaf32c54042adbd2b0
      https://github.com/OSGeo/grass/commit/e1e37d87e78212dfcf4c97aaf32c54042adbd2b0
  Author: luzpaz <luzpaz at users.noreply.github.com>
  Date:   2025-03-07 (Fri, 07 Mar 2025)
  Changed paths:
    M raster/r.category/r.category.html
    M raster/r.category/r.category.md
    M raster/r.contour/main.c
    M raster/r.describe/r.describe.html
    M raster/r.describe/r.describe.md
    M raster/r.gwflow/main.c
    M raster/r.gwflow/r.gwflow.html
    M raster/r.gwflow/r.gwflow.md
    M raster/r.horizon/main.c
    M raster/r.in.ascii/gethead.c
    M raster/r.in.pdal/grassrasterwriter.h
    M raster/r.in.poly/r.in.poly.html
    M raster/r.in.poly/r.in.poly.md
    M raster/r.li/r.li.daemon/daemon.h
    M raster/r.mapcalc/map.c
    M raster/r.mapcalc/map3.c
    M raster/r.mapcalc/testsuite/const_map_test.sh
    M raster/r.mask.status/r.mask.status.html
    M raster/r.mask.status/r.mask.status.md
    M raster/r.out.ppm3/r.out.ppm3.html
    M raster/r.out.ppm3/r.out.ppm3.md
    M raster/r.out.vrml/put_grid.c
    M raster/r.param.scale/interface.c
    M raster/r.param.scale/main.c
    M raster/r.param.scale/param.h
    M raster/r.profile/r.profile.html
    M raster/r.profile/r.profile.md
    M raster/r.resamp.bspline/r.resamp.bspline.html
    M raster/r.resamp.bspline/r.resamp.bspline.md
    M raster/r.resamp.rst/DESCRIPTION
    M raster/r.resamp.rst/main.c
    M raster/r.ros/main.c
    M raster/r.sim/simlib/input.c
    M raster/r.solute.transport/main.c
    M raster/r.spread/main.c
    M raster/r.spread/replaceHa.c
    M raster/r.spread/spread.c
    M raster/r.stats/cell_stats.c
    M raster/r.stats/stats.c
    M raster/r.stream.extract/dseg.c
    M raster/r.stream.extract/main.c
    M raster/r.sun/main.c
    M raster/r.surf.contour/r.surf.contour.html
    M raster/r.surf.contour/r.surf.contour.md
    M raster/r.texture/r.texture.html
    M raster/r.texture/r.texture.md
    M raster/r.thin/io.c
    M raster/r.thin/r.thin.html
    M raster/r.thin/r.thin.md
    M raster/r.timestamp/test_suite/test.r.timestamp.sh
    M raster/r.uslek/prct2tex.c
    M raster/r.viewshed/distribute.cpp
    M raster/r.viewshed/distribute.h
    M raster/r.viewshed/grass.cpp
    M raster/r.viewshed/main.cpp
    M raster/r.viewshed/visibility.cpp
    M raster/r.walk/TODO
    M raster/r.watershed/shed/com_line.c
    M raster/r.watershed/testsuite/r_watershed_test.py
    M raster/rasterintro.html
    M raster/rasterintro.md
    M raster3d/r3.gwflow/main.c
    M raster3d/r3.in.v5d/r3.in.v5d.html
    M raster3d/r3.in.v5d/r3.in.v5d.md
    M raster3d/r3.in.v5d/v5d.c
    M raster3d/r3.info/main.c
    M raster3d/r3.out.ascii/main.c
    M raster3d/r3.out.v5d/main.c
    M raster3d/r3.out.v5d/r3.out.v5d.html
    M raster3d/r3.out.v5d/r3.out.v5d.md
    M raster3d/r3.out.v5d/v5d.c
    M raster3d/r3.out.vtk/testsuite/test_r3_out_vtk.sh
    M raster3d/r3.timestamp/test_suite/test.r3.timestamp.sh
  Log Message:
Found via `codespell -q 3 -S "*.po,*.pot,*.ps,*.raw,*.svg,./contributors_extra.csv,./translators.csv,./mswindows/external,./lib/external,./utils/fix_typos.sh" -L aline,alle,alog,ans,anull,apoints,asnd,attch,bufer,buffr,bui,buildin,build-in,bund,clen,co-ordinate,co-ordinates,datas,delt,doubleclick,dout,dudo,dum,dyin,enew,entrys,eto,fle,flor,fpr,fromm,greif,huld,ihs,indx,ine,ines,infex,infp,inout,inpt,ist,linke,linz,lsat,makin,mapp,mis,modul,nam,nams,nd,neast,ned,nin,numer,observ,offsetp,oint,ons,ontext,parm,parms,partialy,redner,re-use,re-used,rin,selectin,sistem,siz,strin,strng,tht,vas,vizual`
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
