[GRASS-git] [OSGeo/grass] 813c42: grass.temporal: fix error handling (#5631)
Edouard Choinière
noreply at github.com
Mon May 19 18:41:40 PDT 2025
Branch: refs/heads/renovate/ubuntu-24.x
Home: https://github.com/OSGeo/grass
Commit: 813c4202c31a6eb497d54e94b0864daa1de02c36
https://github.com/OSGeo/grass/commit/813c4202c31a6eb497d54e94b0864daa1de02c36
Author: Anna Petrasova <kratochanna at gmail.com>
Date: 2025-05-10 (Sat, 10 May 2025)
Changed paths:
M python/grass/temporal/core.py
Log Message:
The problem is caused by #4805, where the psycopg2.Error is used, even when the package is not available.
I also removed try except for sqlite3 since it has been part of standard Python package since Python 2.5.
Commit: 299a28a7d07cbbf3354e68cf41b59a801969199d
https://github.com/OSGeo/grass/commit/299a28a7d07cbbf3354e68cf41b59a801969199d
Date: 2025-05-13 (Tue, 13 May 2025)
Changed paths:
M general/g.region/main.c
Log Message:
g.region: fix save option behavior (#5627)
Adjust the region before saving it. Before, setting rows= and cols= had no effect on the saved region.
Commit: 87819eedf0c6b5c5ec652bd067611882c340d027
https://github.com/OSGeo/grass/commit/87819eedf0c6b5c5ec652bd067611882c340d027
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2025-05-14 (Wed, 14 May 2025)
Changed paths:
M .github/workflows/documentation.yml
Log Message:
CI(docs): Remove repository input when checking-out grass core (#5640)
Commit: 1613a870520fabb6c0c7d205626afda620e6514c
https://github.com/OSGeo/grass/commit/1613a870520fabb6c0c7d205626afda620e6514c
Changed paths:
M locale/CMakeLists.txt
Log Message:
cmake: Fix CMP0175 warning by adding `POST_BUILD` to `TARGET` form of `add_custom_command()` (#5639)
Commit: a277d8547cf3c3f09042ccea6ef5c0fc2b8b89dd
https://github.com/OSGeo/grass/commit/a277d8547cf3c3f09042ccea6ef5c0fc2b8b89dd
Author: Linda Karlovska <49241681+lindakarlovska at users.noreply.github.com>
Changed paths:
M doc/NIX.md
M doc/debugging.txt
M doc/development/README.md
M doc/development/branching_how-to.md
M doc/development/github_guide.md
M doc/development/style_guide.md
M doc/examples/gui/wxpython/README
M doc/examples/notebooks/README.md
M doc/examples/notebooks/temporal.ipynb
M doc/examples/python/raster_example_ctypes.py
M doc/examples/python/vector_example_ctypes.py
M doc/examples/raster/r.example/r.example.md
M doc/grass_database.md
M doc/howto_release.md
M doc/infrastructure.md
M doc/projectionintro.md
M gui/wxpython/docs/wxGUI.md
M gui/wxpython/docs/wxGUI.modules.md
M gui/wxpython/docs/wxGUI.toolboxes.md
M gui/wxpython/docs/wxgui_sphinx/_templates/layout.html.template
M gui/wxpython/docs/wxgui_sphinx/conf.py
M gui/wxpython/docs/wxgui_sphinx/src/index.rst
M gui/wxpython/docs/wxgui_sphinx/src/wxgui_toolboxes.rst
M lib/init/grass.md
M lib/init/helptext.md
M lib/init/license.txt
M lib/init/variables.md
Log Message:
docs: Standardize naming: use "GRASS" instead of "GRASS GIS" (#5644)
Commit: 7e69717e6cdfcf7b3bbc767f3efe948f1e7ee119
https://github.com/OSGeo/grass/commit/7e69717e6cdfcf7b3bbc767f3efe948f1e7ee119
Date: 2025-05-15 (Thu, 15 May 2025)
Changed paths:
M man/build.py
M man/parser_standard_options.py
Log Message:
man: Remove FileType argument types in parser standard options arguments (#5561)
* man: Write a help description for output argument of Parser standard option
* man: Remove usage of FileType argument type in parser standard options
The argparse FileType argument type will be deprecated in Python 3.14. It does not properly close files if a subsequent error in another FileType argument occurs when parsing. The suggestion is to use context managers after parsing the arguments. The implementation of the changes is inspired by a PR doing the same in the CPython repo.
* man: Remove proxies=None from urlopen, as it is for the old interface
* man: Add typing annotations to related changes of parser standard options
* man: Fix name of file by using outfile.name
Commit: fbf8595643d8972ecf49f958064ad432870cbe9e
https://github.com/OSGeo/grass/commit/fbf8595643d8972ecf49f958064ad432870cbe9e
Changed paths:
Log Message:
CI(docs): Use mold linker (#5642)
Commit: aa45c58503582256c5d566aea86c39cfc84ed769
https://github.com/OSGeo/grass/commit/aa45c58503582256c5d566aea86c39cfc84ed769
Changed paths:
M .github/workflows/test_thorough.bat
Log Message:
CI(OSGeo4W): Temporarily lower gunittest test success threshold (#5655)
Commit: 1d71a72bf3827ba8b25f3d6faa8e6243530f1cad
https://github.com/OSGeo/grass/commit/1d71a72bf3827ba8b25f3d6faa8e6243530f1cad
Author: Jayneel Shah <80264736+jayneel-shah18 at users.noreply.github.com>
Date: 2025-05-16 (Fri, 16 May 2025)
Changed paths:
A imagery/i.evapo.mh/testsuite/test_i_evapo_mh.py
Log Message:
i.evapo.mh: add test file (#5519)
* add test file
* modify docstrings and make edits
* modify existing test to fail because of bug
* changed the stats after bug fix
Commit: ab016ef450de5459d7a31af92f6fe3c76d05d409
https://github.com/OSGeo/grass/commit/ab016ef450de5459d7a31af92f6fe3c76d05d409
Author: Hernán De Angelis <51515911+dhdeangelis at users.noreply.github.com>
Changed paths:
M raster/r.resamp.filter/main.c
Log Message:
r.resamp.filter: correct typo in warning message (#5657)
Commit: dcb44fb035f8e1621d453db530a493214c7ab079
https://github.com/OSGeo/grass/commit/dcb44fb035f8e1621d453db530a493214c7ab079
Author: Corey White <smortopahri at gmail.com>
Changed paths:
M man/mkdocs/requirements.txt
Log Message:
docs: Freezing mkdocs dependencies (#5648)
Commit: b5c3282a0efedd499dbaee85d510d0fd728e6e98
https://github.com/OSGeo/grass/commit/b5c3282a0efedd499dbaee85d510d0fd728e6e98
Changed paths:
M gui/wxpython/mapdisp/frame.py
Log Message:
wxGUI: Fix uninitialized variables in DOutFile() method (#5650)
* fix uninitialized variables in DOutFile() method
Co-authored-by: lindakladivova <l.kladivova at seznam.cz>
Co-authored-by: Anna Petrasova <kratochanna at gmail.com>
Commit: 821edd0371b321c338290b7bad40a0a72dac2ee2
https://github.com/OSGeo/grass/commit/821edd0371b321c338290b7bad40a0a72dac2ee2
Changed paths:
M lib/init/grass.py
Log Message:
grass.py: Standardize naming: use "GRASS" instead of "GRASS GIS" (#5645)
replace grass gis by grass in grass.py
Commit: ebc98ba0a573bf83e31b9e89542388e270b5d66d
https://github.com/OSGeo/grass/commit/ebc98ba0a573bf83e31b9e89542388e270b5d66d
Author: luzpaz <luzpaz at users.noreply.github.com>
Changed paths:
M python/grass/script/core.py
M python/grass/script/db.py
M python/grass/script/setup.py
M python/grass/script/tests/conftest.py
M python/grass/script/tests/utils_test.py
M python/grass/script/utils.py
Log Message:
grass.script: fix typos (#5638)
python/grass/script: fix typos
Found via codespell
Commit: 3c61b260544baf6b853e7fb5eeb105aa2b138c5c
https://github.com/OSGeo/grass/commit/3c61b260544baf6b853e7fb5eeb105aa2b138c5c
Changed paths:
M python/grass/gunittest/checkers.py
M python/grass/gunittest/gutils.py
M python/grass/gunittest/multireport.py
M python/grass/gunittest/reporters.py
M python/grass/gunittest/testsuite/test_assertions_vect.py
Log Message:
grass.gunittest: fix typos (#5637)
python/grass/gunittest: fix typos
Found via codespell
Commit: 57064d631c6b23db1682fd68783d384d048daef8
https://github.com/OSGeo/grass/commit/57064d631c6b23db1682fd68783d384d048daef8
Changed paths:
M python/grass/docs/conf.py
M python/grass/docs/src/gunittest_testing.rst
M python/grass/docs/src/pygrass_gis.rst
M python/grass/docs/src/pygrass_vector.rst
M python/grass/docs/src/temporal_framework.rst
Log Message:
docs: fix typos in Python doc (#5636)
python/grass/docs: fix typos
Found via codespell
Commit: 1053aee35cf2816535a098c05bd99b3022724802
https://github.com/OSGeo/grass/commit/1053aee35cf2816535a098c05bd99b3022724802
Changed paths:
M python/grass/temporal/abstract_space_time_dataset.py
M python/grass/temporal/spatial_extent.py
M python/grass/temporal/spatio_temporal_relationships.py
M python/grass/temporal/temporal_algebra.py
M python/grass/temporal/temporal_operator.py
M python/grass/temporal/testsuite/unittests_temporal_algebra_grs.py
Log Message:
grass.temporal: fix typos (#5635)
python/grass/temporal: fix typos
Found via codespell
Commit: 6e16f7c559fb85eef553cae9cfb64460acac51de
https://github.com/OSGeo/grass/commit/6e16f7c559fb85eef553cae9cfb64460acac51de
Author: Kriti Birda <164247895+kritibirda26 at users.noreply.github.com>
Changed paths:
M vector/CMakeLists.txt
M vector/v.to.db/Makefile
M vector/v.to.db/global.h
M vector/v.to.db/main.c
M vector/v.to.db/parse.c
M vector/v.to.db/report.c
A vector/v.to.db/testsuite/test_v_to_db.py
M vector/v.to.db/units.c
M vector/v.to.db/v.to.db.html
Log Message:
v.to.db: add JSON support (#4036)
Commit: 8d9e114e26b2c72e3220456fcd4814f6d4f63e1b
https://github.com/OSGeo/grass/commit/8d9e114e26b2c72e3220456fcd4814f6d4f63e1b
Changed paths:
Log Message:
CI(docs): Add ccache to builds (#5641)
Commit: 050dbc5c9d392c5a47ea1bb112b46dec92063076
https://github.com/OSGeo/grass/commit/050dbc5c9d392c5a47ea1bb112b46dec92063076
Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Date: 2025-05-17 (Sat, 17 May 2025)
Changed paths:
M .github/workflows/codeql-analysis.yml
M .github/workflows/python-code-quality.yml
Log Message:
CI(deps): Update github/codeql-action action to v3.28.18 (#5664)
Commit: 8888c179051b1ee1f466afe3d4d1858837a39227
https://github.com/OSGeo/grass/commit/8888c179051b1ee1f466afe3d4d1858837a39227
Changed paths:
M .pre-commit-config.yaml
Log Message:
CI(deps): Update ruff to v0.11.10 (#5665)
Commit: 3fc104c93d35e4e03d60d75af35c69c7c28641e3
https://github.com/OSGeo/grass/commit/3fc104c93d35e4e03d60d75af35c69c7c28641e3
Changed paths:
M .github/workflows/docker.yml
Log Message:
CI(deps): Update docker/build-push-action action to v6.17.0 (#5667)
Commit: 1ec957753bbba7c406cb7ad14570744f53835d22
https://github.com/OSGeo/grass/commit/1ec957753bbba7c406cb7ad14570744f53835d22
Changed paths:
M .github/workflows/pytest.yml
Log Message:
CI(deps): Update codecov/codecov-action action to v5.4.3 (#5666)
Commit: cecfaa680fb619b37c7c97f8361b5343d986a591
https://github.com/OSGeo/grass/commit/cecfaa680fb619b37c7c97f8361b5343d986a591
Changed paths:
M .github/workflows/super-linter.yml
Log Message:
CI(deps): Update super-linter/super-linter action to v7.4.0 (#5668)
Commit: 7355fca67d26fdcd13abcfcb3ea74c5352506f48
https://github.com/OSGeo/grass/commit/7355fca67d26fdcd13abcfcb3ea74c5352506f48
Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
Changed paths:
M man/grass_logo.png
Log Message:
docs: fix GRASS logo image size (#5662)
Commit: 58d34ea42d49805a27a9645b7066b967445fd8a5
https://github.com/OSGeo/grass/commit/58d34ea42d49805a27a9645b7066b967445fd8a5
Changed paths:
Log Message:
g.region: remove unnecessary temp_window variable (#5658)
Follow up on #5627. temp_window is still used elsewhere, so it should not be removed completely.
Commit: e081cb5bbd8826427ca8ea9177c244be3d375dcc
https://github.com/OSGeo/grass/commit/e081cb5bbd8826427ca8ea9177c244be3d375dcc
Date: 2025-05-19 (Mon, 19 May 2025)
Changed paths:
M flake.lock
M flake.nix
M package.nix
Log Message:
nix: Update to Python 3.12 (#5550)
Commit: 472e944007c82d0808a795c6b4e4a52ffcd97949
https://github.com/OSGeo/grass/commit/472e944007c82d0808a795c6b4e4a52ffcd97949
Author: Ivan Mincik <ivan.mincik at gmail.com>
Changed paths:
M flake.lock
M package.nix
Log Message:
nix: update packaging (#5671)
Commit: e0cae00e3794127bfb4508b3cfbcbc409c80c4f9
https://github.com/OSGeo/grass/commit/e0cae00e3794127bfb4508b3cfbcbc409c80c4f9
Changed paths:
M .github/workflows/gcc.yml
M .github/workflows/ubuntu.yml
Log Message:
CI: Temporarily disable jobs for optimizing CI time during sprint (#5670)
* CI: Temporarily disable matrix strategies
For optimizing CI usage during a coding sprint
* CI: Combine gcc workflow flags with Ubuntu jobs
* CI: Disable pull_request trigger in GCC workflow
Commit: ac58e93b447aa844be26f45652e2202aa25259ab
https://github.com/OSGeo/grass/commit/ac58e93b447aa844be26f45652e2202aa25259ab
Changed paths:
M flake.nix
Log Message:
nix: use default python version for nix dev environment (#5672)
This is a follow-up of #5671.
Commit: 01f1bb44b9df33803e83b9e3c52a28102000f6d8
https://github.com/OSGeo/grass/commit/01f1bb44b9df33803e83b9e3c52a28102000f6d8
Changed paths:
M scripts/d.polar/polar_diagram.eps
M scripts/d.polar/ps_defs.eps
M scripts/g.extension/g.extension.py
M scripts/g.extension/testsuite/test_addons_download.py
M scripts/i.pansharpen/i.pansharpen.py
M scripts/r.colors.stddev/r.colors.stddev.html
M scripts/r.colors.stddev/r.colors.stddev.md
M scripts/r.in.wms/wms_cap_parsers.py
M scripts/v.dissolve/tests/v_dissolve_aggregate_test.py
M scripts/v.dissolve/v_dissolve.ipynb
M scripts/v.to.lines/v.to.lines.py
Log Message:
docs: fix typos found via codespell in scripts (#5474)
Commit: 1df16fe61e419d9f2abc1aedcc9fede1487293cf
https://github.com/OSGeo/grass/commit/1df16fe61e419d9f2abc1aedcc9fede1487293cf
Changed paths:
M include/Make/Doxyfile_arch_html.in
M include/Make/Doxyfile_arch_latex.in
M include/grass/gis.h
M include/grass/iostream/embuffer.h
M include/grass/iostream/imbuffer.h
M include/grass/vect/dig_macros.h
M include/grass/vect/dig_structs.h
Log Message:
docs: fix typos in include (#5473)
Commit: 83a850bd62fdc8b8be3f17b1e26dbbcbc5e14426
https://github.com/OSGeo/grass/commit/83a850bd62fdc8b8be3f17b1e26dbbcbc5e14426
Author: Neel Ghoshal <72409908+NeelGhoshal at users.noreply.github.com>
Changed paths:
M CONTRIBUTING.md
Log Message:
docs: Changed instances of 'GRASS GIS' (#5674)
Changed 'GRASS GIS' to 'GRASS' in CONTRIBUTING.MD
Commit: 570052509fd82f34b3635d5147810b4100cf8076
https://github.com/OSGeo/grass/commit/570052509fd82f34b3635d5147810b4100cf8076
Author: Martin Landa <landa.martin at gmail.com>
Changed paths:
M lib/gis/parser_md.c
Log Message:
libgis: G__usage_markdown() include tool label in metadata if defined (#5677)
md metadata: include tool label in description (some of tools have only label defined, eg. r.relief)
Commit: e8a22ab407f3a668ecb6c7cf8e4aca1232b55d6b
https://github.com/OSGeo/grass/commit/e8a22ab407f3a668ecb6c7cf8e4aca1232b55d6b
Changed paths:
M CONTRIBUTING.md
M doc/NIX.md
M doc/debugging.txt
M flake.lock
M flake.nix
M lib/init/grass.md
M lib/init/grass.py
M man/build.py
M package.nix
Log Message:
Merge branch 'main' into renovate/ubuntu-24.x
Compare: https://github.com/OSGeo/grass/compare/fb6005468264...e8a22ab407f3
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
