[GRASS-git] [OSGeo/grass] cd88e2: tests: Add tests for error states in r.mapcalc (#6...
Vaclav Petras noreply at github.com
Fri Oct 10 07:59:35 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: cd88e2c882d0fcc95fce600bfe5d84e4c416dbf6
      https://github.com/OSGeo/grass/commit/cd88e2c882d0fcc95fce600bfe5d84e4c416dbf6
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2025-10-10 (Fri, 10 Oct 2025)
  Changed paths:
    A raster/r.mapcalc/tests/r_mapcalc_nprocs_test.py
  Log Message:
  tests: Add tests for error states in r.mapcalc (#6476)
The test with the rand function fails with higher number of threads (4 and above in tests). This skips the test problematic test for now. I'm using skip rather than xfail because there is too many different conditions to get that right (macOS does not fail, Windows fails with no stderr, Linux fails with segfault, small nprocs passes).
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
