[GRASS-git] [OSGeo/grass] 4f1c5f: CI: Fix r.texture test on macOS for v8.4 (#6478)
Markus Neteler
noreply at github.com
Wed Oct 15 06:28:03 PDT 2025
Branch: refs/heads/releasebranch_8_4
Home: https://github.com/OSGeo/grass
Commit: 4f1c5f38d26584d40e11c63fe954b874bf99c08d
https://github.com/OSGeo/grass/commit/4f1c5f38d26584d40e11c63fe954b874bf99c08d
Author: Markus Neteler <neteler at osgeo.org>
Date: 2025-10-15 (Wed, 15 Oct 2025)
Changed paths:
M raster/r.texture/testsuite/test_texture.py
Log Message:
* CI: fix raster/r.texture/testsuite/test_texture.py on MacOS (G84)
Attempt to fix:
```sh
Running ./raster/r.texture/testsuite/test_texture.py...
...........F.
FAIL: test_sv (__main__.TestRasterreport.test_sv)
Testing method sv
File "raster/r.texture/testsuite/test_texture.py", line 144, in test_sv
self.assertRasterFitsUnivar(output, reference=values, precision=1e-2)
File "etc/python/grass/gunittest/case.py", line 289, in assertRasterFitsUnivar
self.assertModuleKeyValue(
File "etc/python/grass/gunittest/case.py", line 271, in assertModuleKeyValue
self.fail(self._formatMessage(msg, stdMsg))
AssertionError: r.univar map=sv_SV percentile=90.0 nprocs=1 separator== -g difference:
mismatch values (key, reference, actual): [('max', 45368496, 45368492), ('mean', 2248724.38215788, 2248724.35922656), ('variance', 2332049495199.41, 2332049429651.92)]
command: r.univar map=sv_SV percentile=90.0 nprocs=1 separator== -g {'map': 'sv_SV', 'separator': '=', 'flags': 'g'}
Ran 13 tests in 17.655s
FAILED (failures=1)
* indeed keep IS_MAC condition and update values to let pass CI
* update max values for MacOS
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
