[GRASS-git] [OSGeo/grass] fb0165: CQ: Fix Ruff PTH110: `os.path.exists()` should be ...
Edouard Choinière
noreply at github.com
Tue Oct 21 06:57:37 PDT 2025
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: fb0165c2d021b7700528aca09c224847be871729
https://github.com/OSGeo/grass/commit/fb0165c2d021b7700528aca09c224847be871729
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2025-10-21 (Tue, 21 Oct 2025)
Changed paths:
M display/d.mon/render_cmd.py
M gui/wxpython/animation/data.py
M gui/wxpython/animation/dialogs.py
M gui/wxpython/animation/provider.py
M gui/wxpython/core/gconsole.py
M gui/wxpython/core/globalvar.py
M gui/wxpython/core/render.py
M gui/wxpython/core/settings.py
M gui/wxpython/core/toolboxes.py
M gui/wxpython/core/utils.py
M gui/wxpython/core/watchdog.py
M gui/wxpython/gcp/manager.py
M gui/wxpython/gmodeler/panels.py
M gui/wxpython/gui_core/ghelp.py
M gui/wxpython/gui_core/menu.py
M gui/wxpython/gui_core/pyedit.py
M gui/wxpython/gui_core/widgets.py
M gui/wxpython/iclass/frame.py
M gui/wxpython/icons/icon.py
M gui/wxpython/image2target/ii2t_gis_set.py
M gui/wxpython/image2target/ii2t_manager.py
M gui/wxpython/lmgr/frame.py
M gui/wxpython/lmgr/workspace.py
M gui/wxpython/main_window/frame.py
M gui/wxpython/modules/colorrules.py
M gui/wxpython/modules/import_export.py
M gui/wxpython/nviz/tools.py
M gui/wxpython/photo2image/ip2i_manager.py
M gui/wxpython/psmap/dialogs.py
M gui/wxpython/psmap/instructions.py
M gui/wxpython/rlisetup/functions.py
M gui/wxpython/startup/locdownload.py
M gui/wxpython/tplot/frame.py
M gui/wxpython/wxplot/profile.py
M imagery/i.cluster/testsuite/test_i_cluster.py
M imagery/i.landsat.toar/testsuite/test_i_landsat_toar.py
M imagery/i.rectify/testsuite/test_i_rectify.py
M imagery/i.target/testsuite/test_i_target.py
M lib/gis/testsuite/test_gis_lib_getl.py
M lib/init/grass.py
M locale/grass_po_stats.py
M man/build.py
M man/build_rest.py
M pyproject.toml
M python/grass/app/data.py
M python/grass/app/runtime.py
M python/grass/app/tests/grass_app_resource_paths_test.py
M python/grass/experimental/create.py
M python/grass/experimental/tests/grass_script_mapset_session_test.py
M python/grass/experimental/tests/grass_script_tmp_mapset_session_test.py
M python/grass/grassdb/checks.py
M python/grass/gunittest/invoker.py
M python/grass/gunittest/main.py
M python/grass/gunittest/multireport.py
M python/grass/gunittest/utils.py
M python/grass/jupyter/map.py
M python/grass/jupyter/tests/grass_jupyter_session_test.py
M python/grass/pygrass/vector/__init__.py
M python/grass/pygrass/vector/table.py
M python/grass/script/core.py
M python/grass/script/tests/grass_script_create_project_pack_test.py
M python/grass/script/tests/grass_script_setup_test.py
M python/grass/script/utils.py
M python/grass/temporal/core.py
M python/grass/temporal/stds_import.py
M python/grass/tools/tests/conftest.py
M python/grass/tools/tests/grass_tools_session_tools_pack_test.py
M python/grass/utils/download.py
M raster/r.in.pdal/testsuite/test_r_in_pdal_binning.py
M raster/r.in.pdal/testsuite/test_r_in_pdal_print.py
M raster/r.in.pdal/testsuite/test_r_in_pdal_selection.py
M raster/r.kappa/testsuite/test_r_kappa.py
M raster/r.smooth.edgepreserve/testsuite/test_r_smooth_edgepreserve.py
M raster/r.terraflow/testsuite/test_r_terraflow.py
M scripts/d.polar/d.polar.py
M scripts/db.out.ogr/db.out.ogr.py
M scripts/g.extension.all/g.extension.all.py
M scripts/g.extension/g.extension.py
M scripts/g.extension/testsuite/test_addons_modules.py
M scripts/g.manual/g.manual.py
M scripts/i.oif/testsuite/test_i_oif.py
M scripts/m.proj/m.proj.py
M scripts/r.import/r.import.py
M scripts/r.in.wms/wms_cap_parsers.py
M scripts/r.pack/r.pack.py
M scripts/r.pack/tests/r_pack_test.py
M scripts/r.unpack/r.unpack.py
M scripts/r3.in.xyz/r3.in.xyz.py
M scripts/v.in.e00/v.in.e00.py
M scripts/v.in.lines/v.in.lines.py
M scripts/v.in.wfs/v.in.wfs.py
M scripts/v.pack/v.pack.py
M scripts/v.unpack/v.unpack.py
M temporal/t.rast.export/t.rast.export.py
M temporal/t.rast.out.vtk/t.rast.out.vtk.py
M utils/create_python_init_file.py
M utils/merge_sitemaps.py
M utils/mkdocs.py
M utils/mkhtml.py
M utils/mkmarkdown.py
M utils/test_generate_last_commit_file.py
M utils/thumbnails.py
Log Message:
CQ: Fix Ruff PTH110: `os.path.exists()` should be replaced by `Path.exists()` (#6524)
* CQ: Fix Ruff PTH110: `os.path.exists()` should be replaced by `Path.exists()`
Ruff rule: https://docs.astral.sh/ruff/rules/os-path-exists/
* Update grass.py, grass_script_create_project_pack_test.py, d.polar.py, r_pack_test.py, create_python_init_file.py, globalvar.py, lib/init/grass.py
Co-authored-by: Stefan Blumentrath <stefan.blumentrath at gmx.de>
* Update gui/wxpython/wxplot/profile.py
* Update profile.py
* Apply suggestions from code review for os.path.join
* r.pack: Revert changes for a test that returns a permission error instead of checking if exists or not
* Add typing to python/grass/tools/tests/conftest.py for tmp_path_factory
* Remove wrapping pathlib.Path objects when they are already given in argument as a pathlib.Path in python/grass/tools/tests/grass_tools_session_tools_pack_test.py
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
