[GRASS-git] [OSGeo/grass] 0cb6d7: r.stream.extract: restore removed code making r.st...
Anna Petrasova
noreply at github.com
Tue Oct 28 06:18:20 PDT 2025
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 0cb6d7f4dbcaa5765ba12cb177040f57a6e5b34a
https://github.com/OSGeo/grass/commit/0cb6d7f4dbcaa5765ba12cb177040f57a6e5b34a
Author: Anna Petrasova <kratochanna at gmail.com>
Date: 2025-10-28 (Tue, 28 Oct 2025)
Changed paths:
M raster/r.stream.extract/streams.c
Log Message:
r.stream.extract: restore removed code making r.stream.extract more robust (#6543)
This block got removed as part of compiler warnings cleanup #1248, but the removal broke special cases (#6541).
The intention of r.stream.extract is to use external flow accumulation for stream extraction, but if in doubt follow the A* search direction, i.e. if (fabs(wat_nbr[np_side]) >= max_acc).
Restoring this deleted code block in addition to #6554 should make r.stream.extract robust for special cases as reported in #6541.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
