[GRASS-git] [OSGeo/grass] d0c81f: CQ: Replace crlf check with validation against an ...
Edouard Choinière
noreply at github.com
Thu Sep 25 06:38:54 PDT 2025
Branch: refs/heads/releasebranch_8_4
Home: https://github.com/OSGeo/grass
Commit: d0c81f5bd4633c3820127719caac05a62084cf81
https://github.com/OSGeo/grass/commit/d0c81f5bd4633c3820127719caac05a62084cf81
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2025-09-25 (Thu, 25 Sep 2025)
Changed paths:
A .editorconfig
R .github/workflows/.editorconfig
M .github/workflows/additional_checks.yml
M .github/workflows/super-linter.yml
M .pre-commit-config.yaml
Log Message:
CQ: Replace crlf check with validation against an .editorconfig file (#6070)
Simplified and adapted from #4792.
Fixes https://github.com/OSGeo/grass/pull/6066#issuecomment-3075510813
The action that checks for CRLF has been failing since at least this weekend.
Considering that that action has low chances of beeing fixed in a timely matter, I replaced the functionality with an .editorconfig file and validating against it with editorconfig-checker. Compared to #4792, here I don’t attempt to make the line ending changes persist in the repo through .gitattributes, and ignore a bit more of non-ready config sections (since the functionality replaced was less detailed than what the .editorconfig I already had almost working).
I made the pre-commit run always, and made it faster in consequence to not add a big impact. With hot cache, it is taking 1min-1min10, which is about the same. I knew pre-commit could be faster in CI as I already saw how fast it was in ruff’s own CI when submitting one of my PRs there once. It can still be a bit faster, but it’s enough for today.
* CQ: Add initial .editorconfig file with basic settings
* CI: Add EditorConfig validation to super-linter workflow
* CI: Remove CRLF check from additional_checks.yml workflow
* CQ: Add editorconfig-checker to pre-commit config
* CI: Always run pre-commit in CI
* Update .editorconfig with new whitespace settings for mswindows
* CI: Run pre-commit step with uvx
* CI: Add caching for pre-commit checks in workflow
* Update .editorconfig for Windows batch files
* CI: Remove paths-filter step from additional_checks.yml
* Update additional_checks.yml step setup-uv
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
