[GRASS-git] [OSGeo/grass] 924824: docker: Remove scikit-learn from Alpine test (#6394)
Vaclav Petras noreply at github.com
Thu Sep 25 09:18:43 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 92482400112bf2b29edd8125400405078ab9c961
      https://github.com/OSGeo/grass/commit/92482400112bf2b29edd8125400405078ab9c961
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2025-09-25 (Thu, 25 Sep 2025)
  Changed paths:
    M docker/alpine/grass_tests.sh
  Log Message:
The Docker test with Alpine is using scikit-learn, presuably to support the test of installing r.learn.ml2 (which in theory should install without it). This changes the test to use r.diversity instead of r.learn.ml2 which does not come with any dependency, reducing the setup and teardown phases, while still testing installation of a Python tool from grass-addons.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
