[GRASS-git] [OSGeo/grass] 8f39c4: grass.pygrass: Fix resource_tracker semaphore warn...
SAKET KUMAR MALL noreply at github.com
Fri Aug 21 12:55:01 PDT 2026
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 8f39c47c80befa707f6adf0ea8bc890223d84be1
      https://github.com/OSGeo/grass/commit/8f39c47c80befa707f6adf0ea8bc890223d84be1
  Author: SAKET KUMAR MALL <72020337+saket0187 at users.noreply.github.com>
  Date:   2026-08-21 (Fri, 21 Aug 2026)
  Changed paths:
    M python/grass/pygrass/rpc/base.py
  Log Message:
  grass.pygrass: Fix resource_tracker semaphore warning at exit (#7833)
Unlink the RPC server lock semaphore when the server is stopped, so temporal tools no longer emit a resource_tracker warning at exit.
Note :- Messenger holds the same kind of lock, but bisecting showed only the CLibrariesInterface lock survives to shutdown, so changing its stop() would fix nothing.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
