Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: f5ebd74c5cf2a1c1fdeeee2c5cfa7702f7fdc2e1
https://github.com/OSGeo/grass/commit/f5ebd74c5cf2a1c1fdeeee2c5cfa7702f7fdc2e1
Author: Corey White <smortopahri at gmail.com>
Date: 2026-08-24 (Mon, 24 Aug 2026)
Changed paths:
M gui/wxpython/xml/toolboxes.xml
M vector/CMakeLists.txt
M vector/Makefile
A vector/v.ppa/Makefile
A vector/v.ppa/doc_figures.py
A vector/v.ppa/f_function.c
A vector/v.ppa/g_function.c
A vector/v.ppa/k_function.c
A vector/v.ppa/local_proto.h
A vector/v.ppa/main.c
A vector/v.ppa/result.c
A vector/v.ppa/tests/conftest.py
A vector/v.ppa/tests/v_ppa_test.py
A vector/v.ppa/v.ppa.html
A vector/v.ppa/v.ppa.md
A vector/v.ppa/v_ppa_f.png
A vector/v.ppa/v_ppa_g.png
A vector/v.ppa/v_ppa_k.png
A vector/v.ppa/v_ppa_l.png
A vector/v.ppa/v_ppa_patterns.png
Log Message:
v.ppa: Point Pattern Analysis (#3826)
* v.ppa: Point Pattern Analysis
* Changed how vector ponits are counted
* Update vector/v.ppa/main.c
Co-authored-by: Loïc Bartoletti <lbartoletti at users.noreply.github.com>
* Moved sqrt call outside of ec. distance loop
* Updated docs
* added random seed for random points
* updated g-function to return g-value under csr
* updated g-function docs
* Updated K and L functions and MC Sim
* Added base setup for JSON support
* Added tests
* Added json output to k and l functions
* Added markdown to fix build issue
* Updated docs
* v.ppa: Rework estimators, interface, and tests
Restructure the tool for core inclusion and fix correctness problems
found in review:
- Split main.c into per-function files (g_function.c, f_function.c,
k_function.c, result.c) sharing local_proto.h.
- Use the computational region as the observation window for the
intensity estimate, F function sampling, edge correction geometry,
and default distance range. Points outside the region are ignored
with a warning.
- Add Ripley's isotropic edge correction for the K and L functions
(correction=isotropic|none, default isotropic), using the closed
form for rectangular windows.
- Evaluate K and L up to max_distance (default one quarter of the
shorter region side) instead of the O(n^2) pattern diameter, and
estimate K with one radius query per point.
- Print results to standard output by default with
format=plain|csv|json; JSON output is a records array with method,
point count, intensity, window, and correction metadata. The output
option optionally writes to a file for all methods.
- Fix correctness bugs: intensity truncated to int made the G CSR
reference always zero, kdtree_knn was called with k=2 writing into
scalars, duplicate coordinates were dropped from the k-d tree,
omitting output crashed on fopen(NULL), and num_distances was
ignored by the G and F functions.
- Remove the unfinished Monte Carlo envelope code and the simulations
option; simulation envelopes are planned as a follow-up (see TODO
in the manual).
- Add the nprocs and seed standard options; report all functions
together with their theoretical values under CSR.
- Replace the gunittest testsuite and committed test data with pytest
tests on seeded synthetic patterns that assert agreement with CSR
theory, clustering detection, and edge correction behavior.
- Register the tool in vector/CMakeLists.txt and use grass/gjson.h
instead of the removed grass/parson.h.
- Rewrite the manual pages.
The restructured estimators and the isotropic correction were
implemented with AI assistance; the correction was validated
numerically against a brute-force estimate of the circle fraction
inside the window, and the estimators against CSR theory on seeded
random patterns.
* v.ppa: Add manual figures for the summary functions
Add a pattern map figure (clustered, random, dispersed) rendered with
d.vect and one plot per function comparing the three patterns against
the CSR expectation. The figures are generated by the included
doc_figures.py script from seeded synthetic patterns, so they are
reproducible. Created with AI assistance.
* style: Format cmake files with Gersemi
* Add tool to the 'Vector Report and Statistics' and 'Point Analysis' toolboxes
Co-authored-by: Corey White <ctwhite48 at gmail.com>
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
