[GRASS-git] [OSGeo/grass-website] 1b1672: Single-source brand tokens; remove orphaned style....
Corey White
noreply at github.com
Wed Jul 15 07:44:56 PDT 2026
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass-website
Commit: 1b1672621ea993b26d916054476ceecbe06e22b5
https://github.com/OSGeo/grass-website/commit/1b1672621ea993b26d916054476ceecbe06e22b5
Author: Corey White <smortopahri at gmail.com>
Date: 2026-07-15 (Wed, 15 Jul 2026)
Changed paths:
M config.toml
M content/about/brand.md
M content/about/history/releases.md
M content/about/history/web-evolution.md
R themes/grass/assets/css/style.css
M themes/grass/assets/sass/_colors.scss
A themes/grass/assets/sass/_css-variables.scss
M themes/grass/assets/sass/main.scss
M themes/grass/layouts/partials/head.html
Log Message:
Single-source brand tokens; remove orphaned style.css (issue #600) (#645)
* Fix code-block highlighting and squashed timeline margins (issue #600)
Two regressions surfaced by the Bootstrap 5 / SCSS migration:
- Code blocks rendered dark-on-dark: #599 dropped the highlight.js theme
<link> from head.html, and Hugo's Chroma was double-highlighting fenced
code with an inline monokai background that showed through highlight.js's
translucent GRASS theme. Re-link the highlight.js stylesheet and disable
Chroma (markup.highlight.codeFences = false) so highlight.js is the sole
highlighter.
- History timeline pages (releases, web-evolution) wrapped the timeline in a
bare .row with no .col, so Bootstrap 5's negative row gutter pulled the
content outside the card padding. Add mx-0 to neutralize the gutter.
* Single-source brand tokens; remove orphaned style.css (issue #600)
The brand page documents var(--gs-*) custom properties, but the compiled
stylesheet never defined them: they only lived in a hand-maintained
assets/css/style.css that #599 stopped serving (and in the GRASS core docs).
- add _css-variables.scss: a :root{--gs-*} block generated from the $gs-*
Sass tokens, with the light/lighter/lightest ramp derived from each base
color so every step stays in lockstep; wire it into main.scss
- delete the orphaned assets/css/style.css (superseded by the compiled SCSS;
its post-fork fixes were already ported into the SCSS in #599)
- reconcile token drift at the source: primary-light lighter/lightest use
135 not 138, secondary-light steps use 74,120,125 not 74,121,127
- fix the brand page typo advertising --gs-primary-ligh-color
The token block is self-contained so the same --gs-* set can be exported to
the GRASS core docs (man/mkdocs, python/grass/docs) and the Quarto tutorials
as a follow-up, replacing today's hand-copied duplicates.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-website/settings/notifications
