[GRASS-git] [OSGeo/grass] bcca89: style: Fix raise-without-from-inside-except (B904)...
Edouard Choinière
noreply at github.com
Fri Jul 17 09:05:29 PDT 2026
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: bcca890878070c434e8cb93433d0c597bbf7e9e9
https://github.com/OSGeo/grass/commit/bcca890878070c434e8cb93433d0c597bbf7e9e9
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2026-07-17 (Fri, 17 Jul 2026)
Changed paths:
M gui/wxpython/animation/data.py
M gui/wxpython/animation/nviztask.py
M gui/wxpython/core/settings.py
M gui/wxpython/core/utils.py
M gui/wxpython/dbmgr/base.py
M gui/wxpython/gmodeler/model.py
M gui/wxpython/gui_core/forms.py
M gui/wxpython/gui_core/toolbars.py
M gui/wxpython/mapdisp/main.py
M gui/wxpython/rdigit/controller.py
M gui/wxpython/wxgui.py
M pyproject.toml
M python/grass/gunittest/case.py
M python/grass/imaging/images2avi.py
M python/grass/pydispatch/dispatcher.py
M python/grass/pygrass/raster/category.py
M python/grass/pygrass/rpc/base.py
M python/grass/pygrass/vector/table.py
M python/grass/script/core.py
M python/grass/script/task.py
M python/grass/script/utils.py
M python/grass/script/vector.py
M python/grass/semantic_label/reader.py
M python/grass/utils/download.py
M scripts/r.in.wms/wms_cap_parsers.py
Log Message:
style: Fix raise-without-from-inside-except (B904) (#4032)
Enable the ruff B904 rule and add explicit exception chaining to raise
statements inside except clauses.
Most exceptions are chained with "from error" to preserve the original,
including where the original is also passed into the message of the new
exception, so the detail is both in the message and in the chained traceback;
reducing that duplication is left for later. "from None" is used where the
original would be noise: where it is an implementation detail of the raising
code (for example, IndexError becoming StopIteration) or where the new
exception gives a clearer replacement message (for example, an invalid value
for a database column). In wxGUI, the original error is passed into the new
exception and "from None" is used; that exception is caught immediately and
only its message is shown, so no traceback is produced.
The change covers wxGUI, grass.script, grass.pygrass, grass.gunittest,
grass.imaging, grass.pydispatch, grass.semantic_label, grass.utils, and
r.in.wms.
Related bug fixes included:
* rdigit: "raise ScriptError" raised the class, not an instance. ScriptError
requires a message argument, so this raised TypeError instead, which the
callers' "except ScriptError" handlers did not catch. A failing r.mapcalc
or g.copy resulted in a traceback instead of showing an error message. The
message of the module error is now passed to ScriptError.
* wxGUI toolbars: Remove an unreachable return statement after a raise.
* wxGUI utils: Remove a dead try-except in __ll_parts which could not be
reached and only re-raised an empty ValueError.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
