[GRASS-git] [OSGeo/grass-website] 34d51b: GRASS community map (#169)
Luca Delucchi
noreply at github.com
Sat Jul 18 10:01:34 PDT 2026
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass-website
Commit: 34d51b808a053be580e5e148f75454a7f53adfe5
https://github.com/OSGeo/grass-website/commit/34d51b808a053be580e5e148f75454a7f53adfe5
Author: Luca Delucchi <lucadeluge at gmail.com>
Date: 2026-07-18 (Sat, 18 Jul 2026)
Changed paths:
M .pre-commit-config.yaml
M config.toml
A content/about/community-map.md
M package-lock.json
M package.json
A static/geojson/README.md
A static/geojson/provider.geojson
A static/geojson/user.geojson
A themes/grass/assets/js/community_map.js
M themes/grass/assets/sass/README.md
A themes/grass/assets/sass/_community_map.scss
M themes/grass/assets/sass/main.scss
A themes/grass/layouts/about/community-map.html
M themes/grass/layouts/partials/footer.html
M themes/grass/layouts/partials/head.html
Log Message:
* started to work on community map
* added missing geojson folder
* fixed geojson sintax
* added institutions contributing to GRASS into map
* improved popup info
* changed logo into image to keep the same code in the page
* improved input style
* renamed geojson file
* improved README file for geojson
* fixed name
* fixed typos and updates to newer hugo version
* several small improvements
* improved english
* minor typo
* Apply suggestions from code review
Thanks to @veroandreo @neteler
Co-authored-by: Veronica Andreo <veroandreo at gmail.com>
Co-authored-by: Markus Neteler <markus at neteler.org>
* add space under the map
* fixed popup removing when change layer
Co-authored-by: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
* updated community map to use new implementation
* fixed MD013/line-length
* fixed openlayers style
* small improvements
* Update static/geojson/user.geojson
* renamed files and fixed problem in markdown
Co-authored-by: Corey White <smortopahri at gmail.com>
* fixed loading js file
* fixed missing line at the end of files
* Fix community map: load OpenLayers as UMD, not an esbuild bundle
Hugo's js.Build (esbuild) breaks OpenLayers' internal instanceof checks
(View, Style), so the map crashed at construction with
'TypeError: view.then is not a function' and a bogus 'No fill, stroke,
point, or text symbolizer' error. Load ol as its standalone UMD build
(window.ol) via a script tag instead of bundling it.
Also: fix the initial view center under useGeographic() (plain [lon, lat],
no proj transform), build the popup with DOM APIs instead of innerHTML,
validate feature URLs are http(s), reset the previously highlighted
feature on each click, and switch var to let/const.
* Fix community map docs and lint nits
- Fix malformed user.geojson link in README (stray double paren)
- Add missing EOF newlines to main.scss and _community_map.scss
* fixed name of scss file
* added records to geojson
* added check for geojson files
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-website/settings/notifications
