[GRASS-git] [OSGeo/grass-addons] b22d0c: r.in.ssurgo: Feat imports USDA NRCS SSURGO soil da...
Corey White
noreply at github.com
Mon Jun 1 13:14:06 PDT 2026
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: b22d0caf398d3988178e23c2882f84e26f670a6c
https://github.com/OSGeo/grass-addons/commit/b22d0caf398d3988178e23c2882f84e26f670a6c
Author: Corey White <smortopahri at gmail.com>
Date: 2026-06-01 (Mon, 01 Jun 2026)
Changed paths:
A src/raster/r.in.ssurgo/CMakeLists.txt
A src/raster/r.in.ssurgo/Makefile
A src/raster/r.in.ssurgo/r.in.ssurgo.html
A src/raster/r.in.ssurgo/r.in.ssurgo.ipynb
A src/raster/r.in.ssurgo/r.in.ssurgo.md
A src/raster/r.in.ssurgo/r.in.ssurgo.py
A src/raster/r.in.ssurgo/requirements.txt
A src/raster/r.in.ssurgo/tests/conftest.py
A src/raster/r.in.ssurgo/tests/r_in_ssurgo_test.py
Log Message:
r.in.ssurgo: Feat imports USDA NRCS SSURGO soil data (#1630)
* r.in.ssurgo: Feat imports USDA NRCS SSURGO soil data
* Fixed the SDA query, refactored import logic to be usedfor local and sda querys, added tests
* Fix descrepency between queries
* Added Todo fields
* Apply suggestions from code review
Co-authored-by: Anna Petrasova <kratochanna at gmail.com>
* Added links to data download
Co-authored-by: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
* Removed unused function
* Removed leftover print statement
* Converted print to gs.verbose
* Removed global Tools and clean up import functions
* Removed old unused function
* Added more detail to docs and changed soils_area param to soils
* Removed d flag and updated documentation
* Normalized dominant component queries
* Started SQLite fallabck
* Switch from grass.tools to grass.script
* Added clip vector to region
* Fixed issue with switching session
* Added flag to force sqlite over duckdb for testing
* Fixed issue with uploading local gdb with sqlite
* Fixed soil depth bug
* Made constants from reused ssurgo parts
* Condenced queries into reusable components
* Added additional SSURGO fields to output silt, clay, etc
* Added 3D raster (r3) output for ksat based on user define depth slices
* Clean up
* Updated docs
* removed old comments
* Fixed filename typo
* Removed uneeded parameter section
* Corrected duckdb version
* Removed limit to only accepting A as the master soil horizion
* Updated HSG color scheme to include zero
* Added default bottom depth to parameters'set to 25.4 cm or 10 inches to match master horizon A
* Removed uneeded parts of notebook that were copied from the NRCS notebooks
* Added raster3d keyword
* Renamed variable ssurgo_areas to ssurgo_vector
* Added gs.temp_region calls to raster3d creation
* Updated docs to reflect switching hzdept_r and hzdept_b to type float
* Rephrased docstring to indicate the funtion isn't importing the data
* Reduced sqlite commands into a single execute statement
* Normalized ksat color scheeme accross low, regular, and high values
* Switch function to return vs pass when Weighted component aggregation is selected
* Cleaned up some comments
* Fixed bug with setting ksat raster3d color scheme
* Removed old parameter
* Updated notebook examples
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
