[GRASS-git] [OSGeo/grass] 6128fa: build: Fix findstr syntax for Windows build (#7343)
Huidae Cho noreply at github.com
Thu May 7 19:39:16 PDT 2026
  Branch: refs/heads/releasebranch_8_5
  Home:   https://github.com/OSGeo/grass
  Commit: 6128fa2d8cca45d282b40f9964530e80cb662c9b
      https://github.com/OSGeo/grass/commit/6128fa2d8cca45d282b40f9964530e80cb662c9b
  Author: Huidae Cho <grass4u at gmail.com>
  Date:   2026-05-07 (Thu, 07 May 2026)
  Changed paths:
    M cmake/modules/build_addon.cmake
    M cmake/modules/generate_docs.cmake
  Log Message:
  Commit: f5c9f8c90a4ed346989de1a5f2a802501b2cb2c2
      https://github.com/OSGeo/grass/commit/f5c9f8c90a4ed346989de1a5f2a802501b2cb2c2
  Changed paths:
    M CMakeLists.txt
  Log Message:
  build: Add gui scripts to ALL_MODULES (#7347)
  Commit: eaa79daed99a6acb3cdd62f0acce00d64e4a4728
      https://github.com/OSGeo/grass/commit/eaa79daed99a6acb3cdd62f0acce00d64e4a4728
  Changed paths:
  Log Message:
  build: Remove grep warning about stray backslash before white space (#7349)
  Commit: 6066b5c56452818af1feb5ce2239755a99b04979
      https://github.com/OSGeo/grass/commit/6066b5c56452818af1feb5ce2239755a99b04979
  Changed paths:
    M cmake/modules/build_module.cmake
  Log Message:
  build: Always install to install-time directories only (#7353)
* build: Always install to install-time directories only
* Use GRASS_INSTALL_*
Compare: https://github.com/OSGeo/grass/compare/b28fe3135a09...6066b5c56452
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
