[GRASS-git] [OSGeo/grass-addons] 2163cf: r.richdem: clarify resolveflats input; port dephie...
Andy Wickert
noreply at github.com
Sun May 31 18:21:41 PDT 2026
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: 2163cf63360e0ce5bfae95f4815c63ffbb9dda5c
https://github.com/OSGeo/grass-addons/commit/2163cf63360e0ce5bfae95f4815c63ffbb9dda5c
Author: Andy Wickert <andy at northernwidget.com>
Date: 2026-05-31 (Sun, 31 May 2026)
Changed paths:
M src/raster/r.richdem/r.richdem.dephier/testsuite/test_r_richdem_dephier.py
M src/raster/r.richdem/r.richdem.fsm/testsuite/test_r_richdem_fsm.py
M src/raster/r.richdem/r.richdem.resolveflats/r.richdem.resolveflats.py
Log Message:
r.richdem: clarify resolveflats input; port dephier/fsm tests to step DEM (#1706)
* r.richdem.resolveflats: clarify input must be filled or breached
Closes awickert/r.richdem#2
Co-Authored-By: Claude Sonnet 4.6 <noreply at anthropic.com>
* r.richdem.dephier tests: port to saddle DEM
Replace the channel DEM (ring=3, outlet at right border) with the
shared saddle DEM (ring=9, pit=1, saddle=4) used by the fill and
breach test suites. Pour-point elevation is 5 (border cell adjacent
to the saddle), not 3. All structural assertions remain valid.
Closes awickert/r.richdem#1
* r.richdem.fsm tests: port to saddle DEM
shared saddle DEM (ring=9, pit=1, saddle=4). Pour-point elevation is
5 (border cell adjacent to the saddle). The wet-scenario assertion
(mean_after < mean_before) still holds: ring cells at elevation 9
with wtd=+1.5 give surface elevation 10.5 > pour-point 5, so water
spills and mean wtd decreases.
* r.richdem dephier/fsm tests: rename saddle→step in DEM description
The cell at elevation 4 is not a geomorphological saddle (which would
require lower ground on two opposite sides). It is a step — an
intermediate elevation in the exit path pit(1)→step(4)→border(5).
Co-authored-by: Claude Sonnet 4.6 <noreply at anthropic.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
