[GRASS-git] [OSGeo/grass] 3bbb87: CI(deps): Update actions/labeler action to v7 (mai...
Edouard Choinière
noreply at github.com
Fri Oct 2 05:00:13 PDT 2026
Branch: refs/heads/renovate/main-zizmorcore-zizmor-pre-commit-1.x
Home: https://github.com/OSGeo/grass
Commit: 3bbb87b54cc119a72d0c2696c1a2585754bfb769
https://github.com/OSGeo/grass/commit/3bbb87b54cc119a72d0c2696c1a2585754bfb769
Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Date: 2026-10-01 (Thu, 01 Oct 2026)
Changed paths:
M .github/workflows/label.yml
Log Message:
CI(deps): Update actions/labeler action to v7 (main) (#7991)
Commit: e2e23641a0577093f921ec5c5653f92dee061a17
https://github.com/OSGeo/grass/commit/e2e23641a0577093f921ec5c5653f92dee061a17
Changed paths:
M .github/workflows/additional_checks.yml
Log Message:
CI(deps): Update astral-sh/setup-uv action to v10 (main) (#7992)
Commit: 4e0a6aab2fe73af80d7589d43e1bfb5c6e7b9ae0
https://github.com/OSGeo/grass/commit/4e0a6aab2fe73af80d7589d43e1bfb5c6e7b9ae0
Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
Changed paths:
M gui/wxpython/nviz/mapwindow.py
Log Message:
wxGUI/nviz: fix 'window must be shown' error message during docking undocked 3D view window (#7819)
* wxGUI/nviz: fix handling window resize event only if window is shown on the screen
Fix 'window must be shown' error message during docking undocked 3D view window.
Commit: 2e636fb7a0d111e90fc4f8111d556ff689ff9d96
https://github.com/OSGeo/grass/commit/2e636fb7a0d111e90fc4f8111d556ff689ff9d96
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2026-10-02 (Fri, 02 Oct 2026)
Changed paths:
M raster/r.sim/simlib/hydro.c
Log Message:
r.sim: Replace custom chunk computation with OpenMP for loop (#7995)
The walker loop computed each thread's range of walkers by hand from
the thread number and count. A worksharing loop with static schedule
does the same with one pragma, and ends with an implicit barrier, so
code after the loop in the same parallel region sees all walkers
processed without adding an explicit barrier (no barrier in the
current code). The loop variable is private in
a worksharing loop, so it is no longer listed as firstprivate.
Single-threaded results do not change: the depth and discharge maps
computed from the NC SPM elevation, with and without infiltration and
diffusion, are byte-identical to those before this change, and the
run time is the same within noise.
Written with the help of Claude Code.
Commit: 33d985d0bf22fdd04184a46dcc7572e14f8046c3
https://github.com/OSGeo/grass/commit/33d985d0bf22fdd04184a46dcc7572e14f8046c3
Author: Bhuvan Somisetty <somisettybhuvan5 at gmail.com>
Changed paths:
M python/grass/temporal/abstract_space_time_dataset.py
Log Message:
grass.temporal: Raise ValueError on invalid spatial relation (#7949)
Commit: 4eef27770034c15b50b73d9762461252bac2f3d2
https://github.com/OSGeo/grass/commit/4eef27770034c15b50b73d9762461252bac2f3d2
Changed paths:
M .github/workflows/super-linter.yml
Log Message:
CI(deps): Update super-linter/super-linter action to v9 (main) (#7998)
Commit: 39f520150082736998bee78225d4ab2cf47be527
https://github.com/OSGeo/grass/commit/39f520150082736998bee78225d4ab2cf47be527
Changed paths:
M .pre-commit-config.yaml
Log Message:
CI(deps): Update pre-commit hook BlankSpruce/gersemi-pre-commit to v0.29.2 (main) (#7997)
Commit: 5c3ab97e86e1efe9108eb2597064c72424a10c09
https://github.com/OSGeo/grass/commit/5c3ab97e86e1efe9108eb2597064c72424a10c09
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Changed paths:
Log Message:
Merge branch 'main' into renovate/main-zizmorcore-zizmor-pre-commit-1.x
Compare: https://github.com/OSGeo/grass/compare/e3b0a0612262...5c3ab97e86e1
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
