[GRASS-git] [OSGeo/grass] d58e02: grass.pygrass: Fix Ilist.extend and Ilist.remove a...
Bhuvan Somisetty
noreply at github.com
Wed Oct 7 10:18:06 PDT 2026
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: d58e02b86b102fa7ed94f0024585de5c4f8e5461
https://github.com/OSGeo/grass/commit/d58e02b86b102fa7ed94f0024585de5c4f8e5461
Author: Bhuvan Somisetty <somisettybhuvan5 at gmail.com>
Date: 2026-10-07 (Wed, 07 Oct 2026)
Changed paths:
M python/grass/pygrass/vector/basic.py
A python/grass/pygrass/vector/tests/test_basic.py
Log Message:
grass.pygrass: Fix Ilist.extend and Ilist.remove accessing non-existent attribute (#7977)
grass.pygrass: Fix Ilist attribute access, indexing, and append issues
In `python/grass/pygrass/vector/basic.py`, `Ilist.extend()` and `Ilist.remove()`
incorrectly attempted to access `ilist.ilist` and `value.ilist`, which do not
exist on `Ilist` instances (the C pointer is stored in `c_ilist`), resulting
in an `AttributeError`.
Additionally:
- `Ilist.append()` previously used a bare `raise` when `Vect_list_append()` failed;
raise `GrassError` from `grass.pygrass.errors` and coerce `value` with `int()`.
- `Ilist.__getitem__()` negative index calculation allowed negative out-of-bounds
lookups without raising `IndexError`.
- `Ilist.__contains__()` now delegates directly to `contains()` using the C routine.
- Add comprehensive pytest unit tests in `python/grass/pygrass/vector/tests/test_basic.py`.
Fixes #7976.
Signed-off-by: bhuvan-somisetty <somisettybhuvan5 at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
