[GRASS-git] [OSGeo/grass] 14e4e2: style: Strip stray control characters instead of e...
Edouard Choinière
noreply at github.com
Sat Sep 5 12:52:06 PDT 2026
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 14e4e27b7b0a44643e5eb490fdc209b7d3cadb9a
https://github.com/OSGeo/grass/commit/14e4e27b7b0a44643e5eb490fdc209b7d3cadb9a
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2026-09-05 (Sat, 05 Sep 2026)
Changed paths:
M .editorconfig
M lib/external/ccmath/C01-matrix
M raster/r.drain/README
M scripts/r.drain/README
Log Message:
style: Strip stray control characters instead of excluding files (#7891)
The editorconfig-checker bump to v3.11.3 (#7459) added a pre-decode
binary-detection check that flags a file as binary, and thus failing the
utf-8 charset check, if it contains any C0 control byte. Four files were
marked charset = unset as a workaround. Per the discussion in #7888,
three of them hold no meaning in those bytes and are better cleaned up:
- raster/r.drain/README and scripts/r.drain/README contain a stray CAN
(0x18) inside "that differ a little from r.drain".
- lib/external/ccmath/C01-matrix contains a DC3/SYN pair acting as a
subscript toggle around "U1"; the same matrix is spelled U1 plainly
everywhere else in that file.
Only configure still needs the exception: its BEL byte is a legitimate
awk field separator in autoconf-generated code.
Closes #7888
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
