[GRASS-git] [OSGeo/grass] aa1c01: lib/raster3d/tilewrite: Use `>=` for tile index bo...
Edouard Choinière
noreply at github.com
Sun Sep 6 05:25:44 PDT 2026
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: aa1c015fa39f758c48f2267584afc75174e2ba24
https://github.com/OSGeo/grass/commit/aa1c015fa39f758c48f2267584afc75174e2ba24
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2026-09-06 (Sun, 06 Sep 2026)
Changed paths:
A lib/raster3d/tests/lib_raster3d_tilewrite_test.py
M lib/raster3d/tilewrite.c
Log Message:
lib/raster3d/tilewrite: Use `>=` for tile index bounds check (#7723)
* Apply suggested fix to lib/raster3d/tilewrite.c from Copilot Autofix
Co-authored-by: Copilot Autofix powered by AI <223894421+github-code-quality[bot]@users.noreply.github.com>
* lib/raster3d: Add test for Rast3d_write_tile tile index bounds check
Add a pytest test covering the tileIndex bounds check in
Rast3d_write_tile: an index equal to nTiles must be rejected as out of
range, and the last valid index must be accepted. The invalid call runs
in a subprocess using the grass.lib.raster3d ctypes bindings because the
rejection is a fatal error which exits the calling process.
The out-of-range test fails without the bounds check change in this
branch and passes with it.
The test was written by Claude Code using the Claude Fable 5 model.
Co-authored-by: Vaclav Petras <wenzeslaus at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
