[GRASS-git] [OSGeo/grass] b1c85a: lib/vector: Reject out of range categories when re...
R Sai Pranav noreply at github.com
Wed Sep 23 09:57:28 PDT 2026
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: b1c85aeae3498d86b4b3bee25866d859ccaaaad8
      https://github.com/OSGeo/grass/commit/b1c85aeae3498d86b4b3bee25866d859ccaaaad8
  Author: R Sai Pranav <rajasaipranav0 at gmail.com>
  Date:   2026-09-23 (Wed, 23 Sep 2026)
  Changed paths:
    M lib/vector/Vlib/ascii.c
    A vector/v.in.ascii/tests/conftest.py
    A vector/v.in.ascii/tests/v_in_ascii_categories_test.py
  Log Message:
  lib/vector: Reject out of range categories when reading ASCII (#7844)
Vect_read_ascii() passed the layer and category straight to
Vect_cat_set(), whose own range check is commented out, so a value outside
the documented 1 - GV_CAT_MAX range was stored and only caused trouble
later. A point carrying a negative category was skipped by v.out.ogr
without -c and exported twice with it.
Reject the feature at import instead. Category 0 stays allowed, since OGR
layers use it.
Fixes #6563
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
