[GRASS-git] [OSGeo/grass] ce3c00: r.clump: Fail with the clump limit instead of over...
R Sai Pranav noreply at github.com
Wed Sep 23 10:29:28 PDT 2026
  Branch: refs/heads/releasebranch_8_5
  Home:   https://github.com/OSGeo/grass
  Commit: ce3c00073de57ac35542dbb7b7d6a35944c9b55d
      https://github.com/OSGeo/grass/commit/ce3c00073de57ac35542dbb7b7d6a35944c9b55d
  Author: R Sai Pranav <rajasaipranav0 at gmail.com>
  Date:   2026-09-23 (Wed, 23 Sep 2026)
  Changed paths:
    M raster/r.clump/clump.c
  Log Message:
  r.clump: Fail with the clump limit instead of overflowing the index (#7853)
* r.clump: Fail with the clump limit instead of overflowing the index
r.clump asked G_realloc() for 18446744065119617024 bytes and stopped with
a memory error, which reads as a memory problem when it is not one.
label and nalloc are both 32 bit. nalloc starts at INCR and grows in INCR
steps, so it lands exactly on 2^31 and wraps to INT_MIN, and
nalloc * sizeof(CELL) then converts to (size_t)(INT_MIN * 4), which is
18446744065119617024 - the number in the report.
Clump IDs are raster values of type CELL, so as @metzm said on the issue
the limit of one CELL cannot be raised. Report it as the limit it is
instead, and stop INCR short of INT_MAX so nalloc cannot overflow either.
Fixes #6412
* r.clump: Reword the clump limit message
Per review: say "the maximum supported number of clumps". Re-wrapped the
string so the lines stay within 80 columns.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
