s.voronoi: removing duplicate lines
Darrell McCauley
mccauley at ecn.purdue.edu
Wed Apr 8 16:34:58 EDT 1992
How do you remove duplicate lines from vector files?
I'm talking about lines that should be *exactly* the same.
Does v.spag work for this? Should this be something to
consider adding to v.support (I don't think that it has this)?
The problem is the following: I have vertices of polygons
for a vector map (a Voronoi diagram). All boundaries (except for
borders) are shared by two polygons. I'm trying to write a vector
map. I can easily:
1. write each line separately (thus producing many duplicates), or
2. write each polygon as a line (producing spaghetti code or missing
nodes AND duplicates lines).
The correct way of doing this (I guess) would be do store all lines
(either in a large array or in a tmp file), compare each of them,
removing duplicates as I find them (perhaps a unique sort), then write
each as an area edge.
Comments?
BTW, the sun C libs include a quicker-sort (qsort)... can this be
safely used when thinking of portability (for all platforms on which
grass is expected to run)?
--Darrell
