Hi, I'm still having some problems with g.help. The bug fix that Jon Hartmann (Uni of Amsterdam) suggested worked to some extent (thank you), but the menu does not respond to the RETURN key at all (all the items are highlighted). Does anyone have any suggestions please? Thank You. David Chatterton davidc at bruce.cs.monash.edu.au
