Source whereabouts
Conn Copas
C.V.Copas at lut.ac.uk
Tue Aug 4 20:07:02 EDT 1992
A while back, a colleague posted a problem with users being able to kill each
others monitors without permission. Consequently, we've started to look at the
workings of <src/display/d.mon/pgms/stop.c>, but have hit a wall, possibly due
to lack of UNIX expertise. A few questions follow, but first, here is the
relevant code :
/* quiet mode returns: 0 - open OK */
/* -1 - driver locked */
/* -2 - driver not running */
/* -3 - can't open fifos */
/* -4 - no such monitor */
/* -5 - GIS_LOCK undefined in shell environment */
/* -6 - couldn't read, write or create lock file */
#define OK 0
#define LOCKED -1
#define NO_RUN -2
#define NO_OPEN -3
#define NO_MON -4
#define NO_KEY -5
#define LOCK_FAILED -6
stop_mon(name, forced)
char *name;
char *cur, *G__getenv();
int unset;
unset = 0;
cur = G__getenv("MONITOR");
if (cur != NULL && strcmp (cur, name) == 0)
unset = 1;
G__setenv("MONITOR",name);
if (forced)
R_release_driver();
R__open_quiet(); /* call open_driver in quiet mode */
switch (R_open_driver())
case OK:
R_kill_driver();
/*R_close_driver();*/
fprintf(stderr,"Monitor '%s' terminated\n",name);
break;
case NO_RUN:
fprintf(stderr,"Error - Monitor '%s' was not running\n",name);
break;
case NO_MON:
fprintf(stderr,"Error - No such monitor as '%s'\n",name);
break;
case LOCKED:
fprintf(stderr,"Error - Monitor '%s' in use by another user\n",name);
break;
default:
fprintf(stderr,"Error - Locking mechanism failed\n");
break;
if (unset)
G_unsetenv ("MONITOR");
1. HP-UX 8.0 has no system call for <switch>. This function looks awfully like
that which is available through the csh interpreter.
Is it defined somewhere in GRASS src? We can't find it.
2. Our programmer's manual, dated I May 92, lists <R_open_driver> and
<R_close_driver> as library routines, but not <R_open_quiet> or
<R_kill_driver>. Needless to say, we would like to take a hard look at the
latter. Are we even supposed to possess the source somewhere in */lib?
3. Any other suggestions for troubleshooting? The monitor locks file has -1
written to it for running monitors; .gislock has a PID written, as advertised.
The server is a HP-9000. Display systems include SunSparcs and Macs.
Please e-mail replies if not considered of general interest.
Loughborough University of Technology tel : (0509)263171 ext 4164
Computer-Human Interaction Research Centre fax : (0509)610815
Leicestershire LE11 3TU e-mail - (Janet):C.V.Copas at uk.ac.lut
G Britain (Internet):C.V.Copas%lut.ac.uk at nsfnet-relay.ac.uk
