Building xgen for AIX
J H Mintz
ubac1eb at cs.bbk.ac.uk
Mon Jul 6 16:37:05 EDT 1992
I am attempting to build XGEN to run under AIX whcih is using X-windows version 3.
On running make after the setup procedure, the follwoing message was displayed:
make
cc -O -DSYSV -I. -c addnode.c
Processing include file /usr/include/sys/signal.h
63 83 | #define SIGCHLD 20 /* (+) sent to parent on child stop or exit
1506-236: (W) Macro name SIGCHLD has been redefined.
Processing include file ./xgen.h
1501-106: (S) Include file Xm/MwmUtil.h not found.
1501-106: (S) Include file Xm/Protocols.h not found.
Processing include file ./Matrix.h
147 328 | XmTextVerifyCallbackStruct *verify;
....a..................................
a - 1506-046: (S) Syntax error.
1254-004 The error code from the last failed command is 1.
Make Quitting.
It appeared that on our system the 2 include filed mentioned were
in X11 rather than Xm so I changed the source of Xgen.h to reflect
this.Unfortunately, on re-executing make, I still got the syntax error-17 % make
cc -O -DSYSV -I. -I/usr/local/X11R4/include -c addnode.c
148 328 | XmTextVerifyCallbackStruct *verify;
make: 1254-004 The error code from the last command is 1.
Make Quitting.
Does anyone have any experience of setting up Xgen under AIX and
any help with the above problem?
Joe Mintz, Dept Computer Science, Birkbeck College
