MULTIPLE ATTRIBUTES FOR RASTER FILES
Jerry Thompson
thompson at zorro.cecer.army.mil
Mon Mar 2 09:37:43 EST 1992
> > Hi.
> > I need to represent multiple attributes in GRASS raster files.
> > For example, surface roughness, dielectric constant, veg. cover, etc.
> > I can think of two ways to do this:
> > 1. create multiple raster maps for the terrain, one for
> > each attribute. The attribute in each file stores the value
> > for the original attribute.
> > 2. have the single attribute in the raster file store the
> > values of all the attributes after encoding them, e.g.
> > the first digit in the attributes represents roughness,
> > the second, veg. cover, and so on.
> > I can understand that the second method is extremely dirty in terms
> > of simplicity, expandability, etc. But I would like to know if anyone
> > has tried it. ANY other comments are welcome.
> > -Raj
> We are currently working on a GRASS-RDBMS interface which will enable
> multiple attributes to be associated with either raster/vector or
> polygonal features. The current version of the interface is designed
> to be used with INFORMIX RDBMS products. However, the software
> design has been developed with an ey towards easy implementation
> with any ANSI SQL product. The beta release for this code will be
> decided during the users group meeting in Denver. I expect that
> a date in June or July is realistic for Beta code.
> jaf
> James A. Farley email: jim at moray.uark.edu
> Technical Director
> CAST voice: (501)-575-6159
> University of fax: (501)-575-3846
> Arkansas
> Fayetteville, AR 72701
Currently we distribute teh SQL-like dbms RIM with GRASS. Using it (you will
need a Fortran compiler) you can access multiple attributes. It is fairly easy
to write shell scripts that use RIM and v(s).db.rim. One such is:
#!/bin/sh
# usage: dbqueryi data-base vect-map normal-color highlight-color
dbname=$1
file=$2
ncolor=$3
hcolor=$4
d.vect $file c=$ncolor
while true
do
echo
echo "Select a point on the graphics screen with the mouse..."
set `d.where -1 | tr "." " "`
echo "Getting the record from the data base and highlighting the vector..."
v.db.rim $dbname <<EOF
.output /dev/null
.find
$1 $3 1
.vector_map temp.vect
y
!d.vect temp.vect c=$hcolor >/dev/null
.output
.print
.output
.ex
EOF
echo
echo "Enter Q to Quit:"
echo "or ENTER to continue"
read line
d.vect temp.vect c=$ncolor >/dev/null
if [ "$line" = "Q" ]
then
exit
fi
done
You use v.db.rim to build the data base. It will work with either polygonal,
line, or site vector files, or site_list files.
Jerry Thompson
Spatial Analysis Systems Team, USACERL
