Too many cells open (ERROR)
Raghavan Srinivasan srin at ecn.purdue.edu
Tue Mar 17 15:14:56 EST 1992
>It soundsa as if your men/submenu is the culprit. I have looked over
>the code for G_open_cell_new() and G_close_cell() as well as Dcell()
>and they responsibly close all the files they had opened. I suspect
>that you are generating new copies of stdin, stdout, stderr, especially
>since the file descriptor numbers increase by 3 (or else you
>are open 3 files and not closing them when you start the submenu).
>Michael Shapiro                        U.S. Army CERL
You are right. I was generating stdin and stdout each time I enter
a submenu. Thanks for the input and the program works fine.
Srinivasan.
