No subject
Greg Koerper
koerper at research.CS.ORST.EDU
Wed Mar 25 22:36:41 EST 1992
Subject: a tweak of g.mapsets
If you're like me and have numerous linked mapsets in your search path, the
interactive version of g.mapsets can be annoying. I've placed a simple
modification on the incoming directory on moon: shar.g.mapsets. It
allows you to add or delete mapsets from the current search path by
prepending the list with a "+" or "-". It also embeds numeric codes in the
current mapset search list which may help you avoid the table lookup task.
To unpack the shar file enter
/bin/sh shar.g.mapsets
A small change to the man is included. Bugs to koerper at cs.orst.edu
(or fix it yourself).
By the way, the gotos are Michael's, not mine.
Greg Koerper Internet: koerper at turing.cs.orst.edu
ManTech Environmental Technology, Inc. UUCP: hplabs!hp-pcd!orstcs!koerper
200 SW 35th St., JSB
Corvallis, OR 97333 "The 90s will make the 60s look like the 50s.
(503) 754-4490 Just ask your kids."
FTS 430-4490
