cp.colr.sh
Lars Schylberg
larss at fmi.kth.se
Fri Apr 2 06:39:35 EST 1993
A couple of weeks ago I was struggling with copying of color tables in
Grass. I was a little disapointed since I didn't get a single reply.
Are you people out there not writing any scripts any more ?
Well I came to a final solution I think. Here is the script if someone
is interested. It has some modification compared to the earlier ones
so those you that have saved those could throw them away I think.
Lars
Lars Schylberg Email: larss at fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
#!/bin/sh
# cp.colr.sh
# Script to copy one color table from one raster map to another raster map
# The script checks if there exists a colr2 file in current mapset
# for the input map and uses this file in that case, since this is the
# file that is used by d.rast, otherwise we use the colr file.
# Copies the colortable to: $LOCATION/colr2/mapset/$out_name unless the output
# map is in the current mapset and there exist no colr file for the output
# then it is written to $LOCATION/colr/$out_name.
# Read 4.0 Programmers Manual 12.10.3.1 for details about colr2 files
# Author: Lars Schylberg ( larss at fmi.kth.se )
# Department of Geodesy and Photogrammetry
# Royal Inst. of Technolgy
# Stockholm, Sweden
# Date: 930325
# History of changes:
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 2 ]
then
echo
echo Usage: `basename $0`
echo ' input=mapname '
echo ' output=mapname '
echo
exit 1
fi
# parse input arguments
for i do
case $i in
input*)
IN=`echo $i | sed s/input=//` ;;
in*)
IN=`echo $i | sed s/in=//` ;;
i*)
IN=`echo $i | sed s/i=//` ;;
output*)
OUT=`echo $i | sed s/output=//` ;;
out*)
OUT=`echo $i | sed s/out=//` ;;
o*)
OUT=`echo $i | sed s/o=//` ;;
echo ""
echo "Unrecognized option: $i"
echo 'Options: input=mapname '
echo
exit 1
esac
done
# Check the input arguments
eval `g.findfile element=cell file=$OUT`
if [ ! "$file" ] ; then
echo "$OUT - cell file not found"
exit 2
fi
eval `g.findfile element=cell file=$IN`
echo "$IN - cell file not found"
exit 2
fi
# Look for input colr file
eval `g.findfile element=colr file=$IN`
echo "$IN - color file not found"
exit 2
fi
IN_FILE=$file
IN_MAPSET=$mapset
# Use only the first part of the file
# name since the file parameter requires that
IN_NAME=`echo $IN | awk -F@ '{ printf "%s\n", $1 }'`
# Check if the input map has a colr2 file in
# current mapset. Use this if it exists.
# Here we shouldn't use the mapset
# specification in the file parameter
# if one it is given on the command line
eval `g.findfile element=colr2/$IN_MAPSET file=$IN_NAME`
if [ "$file" ] ; then
IN_FILE=$file
fi
# Check for existance of colr file and if output
# file is in current mapset.
OUT_NAME=`echo $OUT | awk -F@ '{ printf "%s\n", $1 }'`
OUT_MAPSET=$mapset
# Here we should use the mapset
eval `g.findfile element=colr mapset=$OUT_MAPSET file=$OUT_NAME`
# case 1: no colr file but same mapset
# case 2: colr file exist, we don't want
# to overwrite or different mapsets
if [ ! "$file" -a "$OUT_MAPSET" = "$MAPSET" ] ; then
OUT_FILE=$LOCATION/colr/$OUT_NAME
SAMEMAPSET=1
else
OUT_FILE=$LOCATION/colr2/$OUT_MAPSET/$OUT_NAME
SAMEMAPSET=0
fi
# Make sure that output path exists
# if the output is in another mapset.
if [ ! -d $LOCATION/colr2 -a $SAMEMAPSET -eq 0 ] ; then
echo "Creating: $LOCATION/colr2"
mkdir $LOCATION/colr2
fi
if [ ! -d $LOCATION/colr2/$OUT_MAPSET -a $SAMEMAPSET -eq 0 ] ; then
echo "Creating: $LOCATION/colr2/$OUT_MAPSET"
mkdir $LOCATION/colr2/$OUT_MAPSET
fi
# Copy the color file
echo "Executing: cp $IN_FILE $OUT_FILE"
