distance calculations
Raymond Venneker
venn at geo.vu.nl
Wed Aug 4 06:41:38 EDT 1993
> Does any have any comments on this? I hasten to
> report this as a bug (and waste someone's time
> at OGI) if I am doing something silly, but
> after having a few nights to sleep on it, I
> still don't see anything wrong. --Darrell
There is a bug, but not in this code. The compiler ``thinks''
G_distance() returns an int because it is not declared in
gis.h as a double. (see fix below.)
-Raymond
> I wrote on 31 Jul 93:
> >I'm trying to do distance calculations. Here's a full sample
> >program:
> >#include <math.h>
> >#include "gis.h"
> >int main (argc, argv)
> > char **argv;
> > int argc;
> > double x1=8.0,y1=7.0,x2=6.0,y2=5.0;
extern double G_distance(); /* <<<< should have been in gis.h */
> > G_gisinit (argv[0]);
> > printf ("projection: %d\n", G_begin_distance_calculations());
> > printf ("G_distance: %g\n", G_distance (x1,y1,x2,y2));
> > printf (" hypot: %g\n", hypot (x1-x2,y1-y2));
> >Is there any thing wrong with this? I run this simple
> >program under (x,y), LL, and utm, I get the same answers:
> > GRASS 4.1 > simple
> > projection: 0
> > G_distance: 8
> > hypot: 2.82843
> >(that is, except for the projection). A distance of 8 is clearly
> >wrong.
> >I am linking the math library and $(GISLIB) when compiling.
> >G_distance should just return factor*hypot (x1-x2,y1-y2), where
> >G_begin_distance_calculations() initializes factor to be 1.0
> >(for utm and x-y).
> >What's going on here? %-|
