xgdisplay
Andy Burnett
burnett at zorro.cecer.army.mil
Thu Jul 15 15:30:41 EDT 1993
In info.grass.programmer you write:
>I am trying to overlay raster images (such as roads on geology) using
>the xgdisplay utility. I have not found how this can be done. Can
>anyone provide any suggestions. Thanks in advance.
When you have the geoframe selected that has the geology map, click on
the maps menu item, select vector and then select roads. The roads vector
map will then be drawn on the raster map.
&y
