XGRASS Problem
nieuwlnd at sci.kun.nl
Fri Jul 16 08:13:30 EDT 1993
The error messages will disappear when you change your path so your system
will look at the Motif libraries first, before looking at the openwindows
libraries. Both packages have a library with the same name but slightly
different contents.
Note: Openwindows may act a bit strange after this -> same problem but reversed
Olga van de Veer,
