freeing dynamic memory in the r.le programs
Darrell McCauley
mccauley at ecn.purdue.edu
Sun Jul 18 19:39:24 EDT 1993
BAKERWL (BAKERWL at corral.uwyo.edu) writes on 18 Jul 93:
>I have used the following code to allocate and free memory in one of the
>r.le programs:
> pt = (int *)G_calloc(100, sizeof(int));
> for (i=0; i<100; i++)
> free(pt[i]);
> free(pt);
>is "int *pt;" before the above code. This problem was found by Lars
My understanding of C is that you only need one call to
free for every malloc call. Therefore,
free(pt);
should be sufficient.
When higher dimension arrays are used, then you have to
call free more than once. For example, for an NxN array:
int **pt;
if ( (pt = (int **) malloc(N*sizeof(int *))) == NULL)
fprintf(stderr,"opps\n"), exit(-1);
for (i=0;i<N;++i)
if ( (pt[i] = (int *) malloc(N*sizeof(int))) == NULL)
for (i=0;i<N;++i)
free(pt[i]);
free(pt);
see the FAQ for comp.lang.c (available via anonymous ftp
from rtfm.mit.edu:pub/usenet/comp.lang.c).
BTW, is there a nice way to run lint with the Gmakefile
setup? I currently do something like this:
CC = lint
COMPILE_FLAGS =
--Darrell
