No subject
Net.Noise owner
news at max.cecer.army.mil
Mon Jul 19 17:18:29 EDT 1993
Newsgroups: info.grass.programmer
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: freeing dynamic memory in the r.le programs
Message-ID: <CAFKIr.7IK at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <5238311518071993_A00879_POSSE_117793CF1300*@mrgate.uwyo.edu>
Date: Mon, 19 Jul 1993 21:18:26 GMT
Lines: 42
In <5238311518071993_A00879_POSSE_117793CF1300*@mrgate.uwyo.edu> BAKERWL at corral.uwyo.edu (BAKERWL) writes:
>I have used the following code to allocate and free memory in one of the
>r.le programs:
> pt = (int *)G_calloc(100, sizeof(int));
> for (i=0; i<100; i++)
> free(pt[i]);
> free(pt);
>This works fine on Sun systems with a version of Unix System V, but
>produces the compiler message "incompatible integer/pointer combination"
>on Apollo machines with bsd4.3. I forgot to mention that the declaration
>is "int *pt;" before the above code. This problem was found by Lars
>Schylberg.
Based on the code segment, the for loop is the incorrect thing to do. You
only allocated memory for pt, not pt[0] - pt[100] so you should only do
free(pt)
Your compiler is telling you something here. free(pt[i]) is calling
free() with an int, not a pointer.
>Lars was able to fix the problem on the Apollo by replacing free(pt[i])
>with free(&pt[i]). However, when I do this on my Sun I quickly run out
>of memory, indicating that the memory is not being freed correctly.
This is definitely NOT the right thing to do.
>C books about this. Anyone know a universal method for freeing memory
>that will work with System V and bsd?
You are doing (almost) the right things here. SYSV and BSD
use the same free() and malloc() interface.
Michael Shapiro shapiro at zorro.cecer.army.mil
U.S. Army CERL (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
