freeing memory in r.le
BAKERWL BAKERWL at corral.uwyo.edu
Tue Jul 20 00:25:31 EDT 1993
Thanks to Darrel and Michael for help with the memory problem.  It turns
out I was doing a free for each element of the array rather than once
for each malloc call, even though I know better.  The Sun compiler,
however doesn't pick up the error and it also doesn't tell you if you
call free() with an int rather than a pointer.  Lars' Apollo compiler
did find this.  I guess maybe it's good that Sun has unbundled their
C compiler...
	Bill Baker
	bakerwl at corral.uwyo.edu
