please help
Malcolm Williamson
malcolm at cast.uark.edu
Thu Jun 10 11:58:35 EDT 1993
Christine Weiss writes:
> I'm putting together a script for a self-running demo. Would anyone be able to tell me the code for putting in a pause in the demo, and then having the demo resume when the space bar (or any other key) is pressed. I know this code is just a few characte> rs long, I've seen it in someone else's code, but I can't track down that program. Help!
> Thank you very much in advance,
Using bourne shell, I typically use something like this:
echo -n "Hit <return> to continue"
read input
The variable "input" can basically just be ignored in the rest of the program,
if desired.
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
