Xgrass menu colors
David M Johnson -- DMJ Consulting djohnson at rock.concert.net
Mon Jun 21 07:37:21 EDT 1993
To modify the XGRASS text colors, fonts, etc. you need to
edit the XGrass resources file.  It is located in
$(GISBASE)/etc/app-defaults.  For example, if you
want to change the background color to dark blue and
the foreground (text) color to white you would change:
XGrass*foreground: yellow
XGrass*background: grey
to the following:
XGrass*foreground: white
XGrass*background: SlateBlue
I don't think that you can change the position of the pop-up
windows by editing the resource file, however.  There may be
a way.  I'll investigate.
Dave
David M. Johnson, GIS Consultant | 1302 The Oaks, Chapel Hill, NC 27514
and Software Engineer            | 919-967-9727 (djohnson at rock.concert.net)
