g.man, g.cp, etc
mike camann camann at pick.uga.edu
Wed Jun 30 16:05:15 EDT 1993
	>mccauley at ecn.purdue.eduwrites on Wed Jun 30 17:14:58 1993
	>> (btw, does anyone else think that "g.manual" a little long
	for a
	>> command name? :-)
	>> --Darrell
	>Not just too long, I like g.man better because it sounds unix.
	A lot of
	>students I teach are novices to GRASS and UNIX. I think they
	learn faster
	>if things are more consistent. So how about g.rm, g.cp instead
	of
	>g.remove, g.copy, etc.? It would really be great if the
	horrible
	>``option=name1,name2'' command line arguments would replaced
	for
	>unix syntax.
	>Raymond Venneker - Inst. of Earth Sc., Free University
	Amsterdam
Good idea!  If you use csh or tcsh, add the lines:
    echo "alias g.man g.manual" >> $cshrc
    echo "alias g.rm g.remove" >> $cshrc
    echo "alias g.cp g.copy" >> $cshrc
to the file $GISBASE/etc/GIS.sh in the csh|tcsh alternative to the case
"$sh" statement.  Is that clear as mud?  Here's what I mean:
case "$sh" in
csh|tcsh)
    HOME=$LOCATION
    export HOME
    cshrc=$HOME/.cshrc
    tcshrc=$HOME/.tcshrc
    rm -f $cshrc $tcshrc
    echo "set home = $home" > $cshrc
    echo "set history = 30 noclobber ignoreeof" >> $cshrc
    echo "set prompt = '\\" >> $cshrc
    echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >>
    $cshrc
    echo "GRASS 4.1 > '" >> $cshrc
    echo 'set BOGUS=``;unset BOGUS' >> $cshrc
    if [ -r $home/.grass.cshrc ]
    then
	cat $home/.grass.cshrc >> $cshrc
    fi
    if [ -r $home/.cshrc ]
    then
	grep '^ *set  *mail *= *' $home/.cshrc >> $cshrc
    fi
    if [ -r $home/.tcshrc ]
    then
	grep '^ *set  *mail *= *' $home/.tcshrc >> $cshrc
    fi
    if [ -r $home/.login ]
    then
	grep '^ *set  *mail *= *' $home/.login >> $cshrc
    fi
    echo "set path = ( $PATH ) " | sed 's/:/ /'g >> $cshrc
>    #  Added by M. Camann 930630
    cp $cshrc $tcshrc
    $ETC/run $SHELL
    HOME=$home
    export HOME
	This will give you g.man, g.cp, and g.rm, though the options
	still do not adhere to unix conventions.  You _could_ write
	shell scripts instead of simply using aliases and pass their
	arguments according to unix conventions without too much
	difficulty.  Needless to say, you need write permission in
	$GISBASE/etc/GIS.sh in order to add the lines above.
	Of course, if you use some other shell, you'll have to modify
	the command accordingly.
Mike Camann
camann at dial.pick.uga.edu
