copying colr files
Lars Schylberg
larss at fmi.kth.se
Wed Mar 24 05:07:46 EST 1993
Hello Grass users !
For those of you that followed my problems with color files yesterday and
the day before yesterday I will here give you my latest solution to this
problem. I hope that I have learned my lesson about colr2 files now.
I had overseen some possibilities in yesterdays script so here is a new
version of "cp.colr.sh"
I think this script could be educational how the colr2 files work and also
how g.findfile can be used. Please tell me if I have missed something !!
I know that this should be sent to grassp instead but since I sent yesterdays
script to grassu I thought it was better to send this to grassu as well.
Lars
Lars Schylberg Email: larss at fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
#!/bin/sh
# cp.colr.sh
# Script to copy one color table from one raster map to another raster map
# The script checks if there exists a colr2 file in current mapset
# for the input map and uses this file in that case, since this is the
# file that is used by d.rast.
# Copies the colortable to: $LOCATION/colr2/mapset/cellname unless the output
# map is in the current mapset and there exist no colr file for the output
# then it is written to $LOCATION/colr/cellname.
# Read 4.0 Programmers Manual 12.10.3.1 for details about colr2 files
# Author: Lars Schylberg ( larss at fmi.kth.se )
# Department of Geodesy and Photogrammetry
# Royal Inst. of Technolgy
# Stockholm, Sweden
# Date: 930324
# History of changes:
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 2 ]
then
echo
echo Usage: `basename $0`
echo ' input=mapname '
echo ' output=mapname '
echo
exit 1
fi
# parse input arguments
for i do
case $i in
input*)
INPUT=`echo $i | sed s/input=//` ;;
in*)
INPUT=`echo $i | sed s/in=//` ;;
i*)
INPUT=`echo $i | sed s/i=//` ;;
output*)
OUTPUT=`echo $i | sed s/output=//` ;;
out*)
OUTPUT=`echo $i | sed s/out=//` ;;
o*)
OUTPUT=`echo $i | sed s/o=//` ;;
echo ""
echo "Unrecognized option: $i"
echo 'Options: input=mapname '
echo
exit 1
esac
done
# Check the input arguments
eval `g.findfile element=cell file=$OUTPUT`
if [ ! "$file" ] ; then
echo "$OUTPUT - cell file not found"
exit 2
fi
eval `g.findfile element=colr file=$INPUT`
echo "$INPUT - color file not found"
exit 2
fi
INFILE=$file
INMAPSET=$mapset
# Use only the first part of the file
# name since the file paratmeter requires that
INPUT_NAME=`echo $INPUT | awk -F@ '{ printf "%s\n", $1 }'`
# Check if the input map has a colr2 file in
# current mapset. Use this if it exists.
eval `g.findfile element=colr2/$INMAPSET mapset=$MAPSET file=$INPUT_NAME`
if [ "$file" ] ; then
INFILE=$file
fi
# Check for existance of colr file and if output
# file is in current mapset otherwise we can't
# write to it
OUTPUT_NAME=`echo $OUTPUT | awk -F@ '{ printf "%s\n", $1 }'`
OUTPUT_MAPSET=`echo $OUTPUT | awk -F@ '{ printf "%s\n", $2 }'`
eval `g.findfile element=colr mapset=$OUTPUT_MAPSET file=$OUTPUT_NAME`
if [ ! "$file" -a "$MAPSET" = "$mapset" ] ; then
OUTFILE=$LOCATION/colr/$OUTPUT_NAME
SAMEMAPSET=1
else
OUTFILE=$LOCATION/colr2/$INMAPSET/$OUTPUT
SAMEMAPSET=0
fi
# Make sure that output path exists
# if the output is in another mapset.
if [ ! -d $LOCATION/colr2 -a $SAMEMAPSET -eq 0 ] ; then
echo "Creating: $LOCATION/colr2"
mkdir $LOCATION/colr2
fi
if [ ! -d $LOCATION/colr2/$INMAPSET -a $SAMEMAPSET -eq 0 ] ; then
echo "Creating: $LOCATION/colr2/$INMAPSET"
mkdir $LOCATION/colr2/$INMAPSET
fi
# Copy the color file
cp $INFILE $OUTFILE
