v.digit2/solaris 2
Darrell McCauley
mccauley at ecn.purdue.edu
Thu Sep 2 18:07:42 EDT 1993
Olga or whoever is reading grassbugs: consider this a bug report
on slowness of named pipes under Solaris 2, or maybe a mild complaint
about this scheme of communication :)
Darrell McCauley (mccauley at ecn.purdue.edu) writes to grassp-list on 2 Sep 93:
>I have found that if I digitize outside the boundaries
>of my monitor that the slowness all but goes away. Thus,
>the incredible slowness is most likely due to
>the overhead of using named pipes.
!! MAKE FIFOs LOCAL !! MAKE FIFOs LOCAL !! MAKE FIFOs LOCAL !!
here are some timings for v.digit2 using n=800 points: The first
number is at the "processing.." stage. The second number is the time
required after "Do you accept this area line?"
+ machine time 1 time 2 Remarks
a LX 12 min 20 min reported by a user
b LX 209 sec 195 sec my actual timing
c LX 87 sec 80 sec after making named pipe local
d LX 3 sec 3 sec outside the boundary (graphics clipped)
e Sparc 2 10 sec 10 sec w/ graphics run remotely,
running SunOS 4.1.1
This speedup for (c) was obtained simply by making the named pipes for
the graphics on a local disk instead of an NFS-mounted disk (changing
path in monitorcap). The speedup for (d) shows just how much time
the graphics requires (since I did the digitizing outside of the current
viewport). The timings for the Sparc2 (e) were done remotely using the same
digitizer/source code. We just ran a serial line from one room to another,
connecting the digitizer to the Sparc 2, and I ran grass4.1 and v.digit2
on the Sparc 2 while using the LX's console.
For this last one, the named pipes were not local, so we had:
______ _______
|server|------|sparc 2|
__|___ / ____|_____
| LX |--| |--|digitizer|
all disks on server (4.1.3), including named pipes, database, & binaries
grass/v.digit running on sparc 2's cpu
using the LXs display
Granted, some of these results are due to the speed/traffic level
on our local network, but I think that they adequately reflect
performance on a normal day (e.g, for a "heavy traffic" day, see
the results for (a)).
Conclusions: The current method of doing graphics (through named pipes)
is the reason for the significant slow-down under Solaris 2 - apparently
this scheme does not function nearly as fast under this OS. Significant
savings may be made by putting the named pipes on a local disk, but
this does not get us to the performance of the Sparc 2.
Sorts of begs for a *true* XDRIVER (no named pipes),
but who will fund this work?
--Darrell
James Darrell McCauley Dept of Ag Engineering, Purdue Univ
internet: mccauley at ecn.purdue.edu West Lafayette, Indiana 47907-1146, USA
bitnet: mccauley%ecn at purccvm UUCP: pur-ee!mccauley
*** avail. for full time employment 9/94-inquiries welcome (no hh, plz) ***
