PROJ.4.2 release
Gerald I. Evenden
gie at charon.er.usgs.gov
Mon Sep 20 15:11:35 EDT 1993
As promised on 7 Sept. the interim documentation for Rel. 4.2 of PROJ
is now available on charon.er.usgs.gov (128.128.40.24) as the file:
pub/PROJ.4.2.ps.Z
Because of a broken native compiler on DEC 5000 systems, two problems
may arise in compiling the PROJ.4 library. Workaround is to use the
GNU compiler by changing line 31 in the `install' script from:
make install LIB=$lib LIB_NAME=$libname STRTOD='$L(strtod.o)'
to:
make install CC=gcc LIB=$lib LIB_NAME=$libname STRTOD='$L(strtod.o)'
Gerald (Jerry) I. Evenden Internet: gie at charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
fax: (508)457-2310 N.Falmouth, MA 02556-1027
