Error in compilation of GRASS4.1 update 3
Greg Olsen
golsen at larix.unl.edu
Thu Apr 14 19:46:40 EDT 1994
Howdy netters,
I have begun compiling GRASS4.1 update 3, which I downloaded
two days ago, and have run into a problem that baffles me. When
the compilation script gets to compiling the program d.3d, it bombs
with the error message:
cc -s -o /usr/local/grass4.1/etc/bin/main/inter/d.3d OBJ/main.o OBJ/threed.o OBJ/transform.o OBJ/clip.o OBJ/get_range.o OBJ/check_opt.o OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o /usr/local/grass4.1/src/libes/LIB/libD.a /usr/local/grass4..1/src/libes/LIB/libdisplay.a /usr/local/grass4.1/src/libes/LIB/libraster.a /usr/local/grass4.1/src/libes/LIB/libgis.a /usr/local/grass4.1/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
ld: Undefined symbol
__lib_version
*** Error code 2
make: Fatal error: Command failed for target `/usr/local/grass4.1/etc/bin/main/inter/d.3d'
GISGEN failure at STEP: src/display/d.3d
I am running SUNOS 4.1.3 on a SPARCstation 10 with Openwindows 3.0.
I have very little experience at tracking down errors that the linker
spits out. Has anyone run into this problem? How was it resolved?
Thanks.
Happy trails,
Greg Olsen
Department of Forestry, Fisheries and Wildlife
University of Nebraska
Lincoln, NE 68583-0814
Phone: 402-472-9869
e-mail: golsen at unlinfo2.unl.edu
