ALTEK DIGITIZER DRIVER
Martin Ameskamp
ma at informatik.uni-kiel.d400.de
Fri Feb 4 03:11:03 EST 1994
> Also, I think v.digit was changed in GRASS4.1, and there is a "v.digit2" or
> "v.digit.old" code around which is the GRASS4.0 v.digit -- can anyone
> shed some light on this? Has ANYONE got an ALTEK AC31 running WELL on
> GRASS4.1?
To the best of my knowledge, v.digit2 under GRASS4.1 is identical
to v.digit under GRASS4.0. The only change was that in GRASS4.0
you had to write a driver for each digitizer whereas in GRASS4.1
(with v.digit) all you need is a configuration file.
Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma at informatik.uni-kiel.d400.de
